Results 1 to 7 of 7
Thread: Will 1980 Passat Engine fit in 1979 Golf GLD??
    hvellacott Guest
    Hi All,
    Looks like I need a new (secondhand) injector pump for my Golf GLD.
    Saw there is a 1980 Diesel Passat on eBay with good engine/injector pump - just wondered if the engine would fit in the Golf?? Obviously the gearbox will be no good to me, but are all the engine mount threaded holes the same??
    I thought I could maybe swap the entire engine and keep my original motor as a spare. Has anyone done this before??
    Any thoughts?
    Thanks,
    Huw
    brackie Guest
    Yes
    I personally haven't done a swap/replacement but the Golf/Passat blocks are identical.
    Apr 2006
    Hobart,Tas
    You may have to drill the lower engine mtg holes out?
    Gosford Central Coast NSW
    i think its identical - sump is different shape, htats about it
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Camden, Sydney
    I think its the same. shame to pull apart a diesel passat tho.
    Apr 2006
    Hobart,Tas
    On some of the Passat motors the rear or manifold side lower bell housing bolt hole was threaded for a bolt. Being a later motor it might be ok. Check first or else you ain't going to get the gearbox stud through there!!!
    hvellacott Guest
    Thanks again!
    Thanks guys,
    Brilliant response once again.
    I have another question - see my latest post!
    Huw
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  3. Passat 2.0TDI Wagon ::Review by The Age::
    Last Post: 01-03-2007, 09:57 PM
