I personally haven't done a swap/replacement but the Golf/Passat blocks are identical.
Hi All,
Looks like I need a new (secondhand) injector pump for my Golf GLD.
Saw there is a 1980 Diesel Passat on eBay with good engine/injector pump - just wondered if the engine would fit in the Golf?? Obviously the gearbox will be no good to me, but are all the engine mount threaded holes the same??
I thought I could maybe swap the entire engine and keep my original motor as a spare. Has anyone done this before??
Any thoughts?
Thanks,
Huw
You may have to drill the lower engine mtg holes out?
i think its identical - sump is different shape, htats about it
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I think its the same. shame to pull apart a diesel passat tho.
On some of the Passat motors the rear or manifold side lower bell housing bolt hole was threaded for a bolt. Being a later motor it might be ok. Check first or else you ain't going to get the gearbox stud through there!!!
Thanks guys,
Brilliant response once again.
I have another question - see my latest post!
Huw
