Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Who is using 2 stroke in their Diesel?
    Mar 2012
    Albury NSW
    Hey
    I have read the relevant posts here and at freel2.com and was wondering if anybody is actually doing this and if so what 2so are they using?
    Nick
    Dec 2008
    sydney
    I haven't read any of freel2.com, but diesels in cars are normally 4 stroke engines.
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
    Mar 2012
    Albury NSW
    Hey
    I am specifically refering to the notion that 200mL of low or no ash non or partial synthetic mixed into a tank of diesel will help the lubricity of the diesel given that the advent of low sulphur diesel fuels have largely removed the lubricity of diesel and gives the high pressure diesel pump some much needed lubrication. There is also the notion that it enhances the combustion process and increases power and fuel consumption.
    There a gazillion posts on the topic and it bears some merit but i was wondering if anyone has actually used it and if so what have they found.
    Nick
    Nov 2005
    Sydney NSW
    Thumbs up
    Runs great in the Mk3 TDI and the slug Land Rover Defenser 130 300TDI
    Use Castrol Activ 2T.
    Get it at Super Cheap when thery have 20% store wide.
    Otherwise get it from a fuel depot... depot at the farm sells 4lt jug for like $36.00 Still cheaper than 20% off at Supercheap.
    The LR Defender really needs it... car runs like a sewing machine with it in, reduces the mechanical noise from the engine and really makes it easier to drive - less of a slug. On the 600km trip to farm it sits so much better at 110. Doesn't improve the fuel economy in it cause your driving it faster than normally would (especially up hills less gear shifts) but there is less effort to get up to speed and keep it there.
    I run the standard 200:1
    which basically is 50ml per 10 Litre Diesel.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Mar 2012
    Albury NSW
    Hey.
    Does either of the vehicles have a dpf?
    Thanks for the input. I just cant see how it would harm anything. Nothing like a bit of upper cylinder lubrication
    Nick
    Oct 2010
    Melbourne, VIC
    The only thing it can hurt is the DPF and the jury is out on that one.
    I know of 4 here running it in their 1.9 PD TDi's inc me. At least one person claims a small but consistent improvement in mileage and another claims it makes their engine run much smoother. In mine, it seems to make no difference but I figure it can only help with wear (mine is by far the newest of the group). Smoke hasn't changed at all in mine.
    I've conversed with DiscoGeorge and Yamaha-fan over on the Freelander site and I'm convinced that their experiences hold weight.
    I use a TC-3 spec oil which is very low ash (as are the JASO spec FD onwards oils).
    With a non-DPF engine, JASO C would be OK but for cars with a DPF, I'd use TC-3 or JASO FD spec oils. Castrol Activ-2T is JASO FC
    Resident grumpy old fart
    Jun 2006
    Orange NSW
    The DPF can be damaged if you use synthetic. Stick to castor oils and you'll be fine. Castrol R30, Shell Racing M, etc.
    I don't have a DPF, so I can go nuts.
    I've been using Yamalube. It's a synthetic designed for snow mobiles etc, so it has a high detergent quality and actually can strip the carbon buildup in your engine. We tried this in our 2 stroke racing engines and it proved to produce more HP initially, but when used continuously, stripped the carbon from the piston/combustion chamber and caused more blowby and heat transfer (This part is only relevant to the kart racing stuff).. So I ended up with a box of the stuff with no use for it.
    I've used it in the Caddy PD 1.9 TDI and in my Mk1 Golf GLD 1.5 NA. On both accounts I've seen increased fuel economy (around 5%). The GLD starts easier, the Caddy always starts easy.. Both are quieter at first start-up and blow less smoke.
    There's been a few threads previously about this over the last few years.. One got very detailed. Not sure where that went?
    Mar 2012
    Albury NSW
    I am thinking of this Penrite oil.
    MARINE OUTBOARD TWO STROKE OIL - Penrite Oil
    Its zero ash and adheres to TC W3 spec.
    I use elf racing oil for my rotax but have used shell m in the kart but found it leaves a varnish that can block things up. I did find however that my RX7 used to go real well with my leftover kart fuel that had shell m in it.
    If i use the no ash penrite and only use 200ML pet tank.. I just cant see how it will stuff things up honest. If you consider the egr valve and how it spews soot straight into the inlet tract (provent on soon) how can a little bit of oil stuff things.. given that diesel is well um oil...
    Jun 2006
    Orange NSW
    Quote Originally Posted by duderduderini View Post
    Water cooleds are a whole different kettle of fish. We used synthetic in the ARC.. But not to get off topic. Haha.
    Any zero ash 2stroke oil should be fine from all accounts from what I've read.
    Direct injection negates any upper cylinder lubricant benefits, but it would certainly help the pumps.
    I say give it a go. You can also try ATF on older engines. A diesel will run on straight ATF. I use it to prime the injector pump (If I've taken it off, etc) when I don't have any diesel around. Adding some ATF to your fuel can apparently help with lubrication and also clean the varnish from the injector pump etc.
    Adelaide hills, SA
    I wouldn't use that if every forum in the world swear by it. Especially if my engine runs well and the fuel additives do their job.
    Aren't there any purpose made additives for the diesel fuel?
