Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Wheels for MKV Gt TDI
    Nov 2007
    Quote Originally Posted by Pearce View Post
    Hey Buddy,
    I was in two minds about 18s and 19s both in 8.5. They fitted perfectly with the standard +45 offset with no rubbing. the actual wheel arched out away from the tyre, which put it outside the fenders, which mean't it couldn't get a road worthy.
    Well it sounds like they actually didn't fit perfectly then?
    I've been looking into 19's for a while now too - consensus seems to be that to avoid any issues you'd better off getting an 8" wide rim rather than 8.5" , get an offset between +45 and +50 and the centre bore has to be 57.1mm. Recommend tyre width to avoid rubbing problems especially if lowered would be 225 but you may have issues getting the correct load rating, easier with a 235.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Feb 2013
    Vic, Aust
    Well... perfectly in the sense that the design of the wheel meant it wasn't roadworthy. If it didn't arch out it would have been fine.
    Apr 2008
    Flare your guards, you homosexual poofter!
    Feb 2013
    Vic, Aust
    Thanks... flaring them over a cm would have looked ridiculous. I'm sure a "homosexual poofter" would agree.
    Erskineville, NSW
    this car has been salamied
    Dec 2009
    Melb. (SE), VIC
    Quote Originally Posted by ForceFed View Post
    ... my car is salamied.
    LOL
    Hrrm... Another pic of ForceFed's car?
