PM johnc He has 19"s on his GTI
Can anyone tell me what specs I should be looking at with 19' wheels for my gt tdi? Offset, width, centre bore etc.
Thanks, Eddie.
19x8 +45 and run a 225 35 19. You will not get any rubbing issues with this setup. I am running a 19x8.5 +42 with 215 35 19 with no issues and my car is salamied.
2007 Golf MKV 2.0 TDI DSG | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
If I get a chance, I'll take some pics later on today.
Thanks guys, i've been leaning towards 18's at the minute though just for the extra ride comfort... still undecided.
I've got a set of 18" BBS Super RS for sale, uber rare and perfect sizes for golf![]()
It's fine if you're running a 235 but go down to a 215 and the ride becomes somewhat harsher.
Hey Buddy,
I was in two minds about 18s and 19s both in 8.5. I went the 19s and the problem i had was a legal one. They fitted perfectly with the standard +45 offset with no rubbing. I was running 215s which they said was a little small for the 8.5's. The problem was that the actual wheel arched out away from the tyre, which put it outside the fenders, which mean't it couldn't get a road worthy. The point of the fender is to prevent a direct collision with the wheel, which in theory stops the car from flipping in certain typed of accidents. That's why you can't get a road worthy if they are outside of that. Make sure you get the assurance of the seller that they will fit with no problems. Then you are completely safe, and can return them.
That said, i have had the past 4 or 5 months resolving problems with my wheels. I only purchased based on their assurance, which meant i could return them, but.... they sat out so i had to chase him for a refund. Not fun. Should be getting my 19s next week (IN THEORY). Exciting stuff!
Good luck! let us know how you go!
I should specify that i have a MK5 Golf. I would probably recommend that you get 8" width as well, you would get a better tyre fit. Not sure about offset but i'm pretty sure spacers are illegal.
