Well... perfectly in the sense that the design of the wheel meant it wasn't roadworthy. If it didn't arch out it would have been fine.
Well it sounds like they actually didn't fit perfectly then?
I've been looking into 19's for a while now too - consensus seems to be that to avoid any issues you'd better off getting an 8" wide rim rather than 8.5" , get an offset between +45 and +50 and the centre bore has to be 57.1mm. Recommend tyre width to avoid rubbing problems especially if lowered would be 225 but you may have issues getting the correct load rating, easier with a 235.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
Flare your guards, you homosexual poofter!![]()
Thanks... flaring them over a cm would have looked ridiculous. I'm sure a "homosexual poofter" would agree.
this car has been salamied
