Page 1 of 4 123 ... LastLast
Results 1 to 10 of 105
Thread: What are you guys getting?
    Hi guys,
    just filled the polo up for the first time. Dad and i worked it out we got an economy of 5.67L/100km around town and thats on a tight engine.
    what are you guys getting economy wise?
    brackie Guest
    Mixed
    TDI: 5.3L/100 on mixed running, 5.0L/100 on highway.
    Silver Mk1 GLD: 4.7L/100 on mixed running, 5.0L/100 on highway.
    Red Mk1 GLD: 5.0L/100km on mixed running, 5.2L/100 on highway. (Has additional weight of sump guard, aircon and sound proofing.)
    Quote Originally Posted by brackie
    they are some impressive figures brackie!
    did you get my PM mate?
    brackie Guest
    Yeah.... Sorry
    I got your pm and replied. Been distracted a bit by other forum issues. Kinda dampens your enthusiasm
    Not all diesels are created equal. This is a fact of life and time and time again I have seen cars/vans/trucks that should on paper be returning the same fuel consumption getting different results. Those with in-line (multi-element) injection pumps seem less variable, but distributor-type pumps like the VE are very sensitive in the governor area and must be timed accurately to achieve the best results. Most guys know about the "smoke screw" (so called because if you open it you get more smoke and more performance but use more fuel but really a maximum fuel device) so they have a bit of a twiddle. I don't have access to bench test apparatus anymore so I twiddle too and try to achieve a balance between performance and economy. Last time I went to Hobart in the silver Mk1 GLD I had to change the settings of the screw to cut down the smoke in the Hobart traffic. Didn't want an infringement notice or worse still a work order. When I was at Andrew's workshop I borrowed tools to do the adjustment but the next day on the cruze with the other Hobart crew I found it difficult to keep up with them. Andrew also lent me a dial gauge and probe so that I could set the point of injection accurately.
    The biggest variable in diesel fuel consumption is the driver. Drive it like a petrol engined car and you'll get petrol engined fuel consumption. Use the torque band and you'll get there faster and use less fuel.
    brackie Guest
    TDI consumption
    Had a disappointing run to Launceston and back today. The TDI did 5.2L/100km for the trip. I came back across the Asbestos Range which worked her hard but I expected better now she's loosening up. Worked out @ ~ 54mpg using 1g + 4.45L and 1km = 0.625ml.
    Apr 2006
    Hobart,Tas
    About 40,000 kms before they really loosen up Brackie, then the things go heaps better and the consumption improves even more. I had a 2l TDI at work today with 15ooo kms on the clock. He achieves 1150 kms to a tank!!
    May 2006
    Padstow 2211 Sydney
    Quote Originally Posted by brackie View Post
    Silver Mk1 GLD: 5.0L/100 on highway.
    Red Mk1 GLD: 5.2L/100 on highway.
    Hi Brackie, Can you tell me what is your highway cruising speed(s) ? (or range of speed)
    alternate energy vw enthusiast....and general crackpot
    brackie Guest
    Cruising speed
    Quote Originally Posted by Edison View Post
    I have never trusted the speedos and I reckon they're about 8 to 10% optimistic.....but.... I cruise @ 100kph comfortably and she will do 110 all day long....but... there is a significant fuel penalty for that extra 10kph.
    Gosford Central Coast NSW
    i've been doing a LOT of hyway driving lately....
    i cant get worse than 5.6l/100 km, even going 120/130 mostly... but thats with the 5 speed, and my car is quite low as you guys know.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    2005 2.0TDi Sportline Golf - love the way you can drive it hard around town and use all that beautiful torque, make screetchy noises off the line in 1st, 2nd and 3rd gears (DSG) and still walk away with less then 6.5l/100k -
    BUT
    IF you get stuck in trafik, you get 8+l/100k..... might as well do the rat runs and circumnavigate the globe than sit in trafick!!!
    Incidentally, my Satnav (Navman N60i) tells me CONSISTENTLY that the speedo is exactly 10% optimistic - and this error corrects the fuel consumption calculations on the trip comp too!! (Have actually verified Satnav speed at 60, 80 and 100kmh via trafick cop mate!
    Eos Individual 2.0TDi Wheat Beige DSG BiXenon
    Fiat Punto Sport 1.9TDi Red and Zippy
Similar Threads
  1. hi guys new forum member
    By tenji` in forum Mk4 Golf & Bora and New Beetle
    Last Post: 02-08-2006, 09:23 PM
  2. Replies: 12
    Last Post: 23-07-2006, 05:43 PM
  3. Finally got some, sorry guys
    By vinderliker in forum Wheels & Suspension
    Last Post: 11-04-2006, 07:32 PM
