Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 105
Thread: What are you guys getting?
  1. #91
    Adelaide hills, SA
    Quote Originally Posted by GermanwithaVdub View Post
    hard acceleration but shifting at 3500rpm. im worried what the consumption will be when i can shift at redline
    My gues is that your oil consumption will be not noticable - up to 0.75L in 7,500km in just right time for the first oil change.
    Your fuel consumption is showing that you must enjoy driving it as i do: i can't resist to accelerate fast at every oportunity within the safe speed limits.
  2. #92
    Jun 2007
    Chatswood, Sydney
    Quote Originally Posted by MRL T5 View Post
    ah yes... enjoying driving for me is an understatement speaking of speed limits, got flashed from the new speed camera at the bottom of mowbray road after swinging round the corner took all of what? 4 days to get a speeding fine with the new car
    New user account: Mischa
    Have: gt sport tdi, mk2 gti, mk1 3dr
  3. #93
    Gosford Central Coast NSW
    haha - speeding,
    after driving mk1's forever, going into my mk3 td, i've really had to train myself not to speed on the f3 between hornsby and gosford every day. its so easy with those ratio's to cruise at 130-140...
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  4. #94
    Apr 2006
    Hobart,Tas
    Quote Originally Posted by Big Al the Butchers' Pal View Post
    My Golf V 1.6 is used only for travel from Sydney to Hartley, and some occasional running around in Sydney traffic.
    I normally get 950km to a tank and 980 on the odd occasion if I travel too far beyond the fuel light turning on.
    According to my glovebox manual my tank is 60 litres capacity which equates to 6.3 litres per 100km. I use regular unleaded fuel.
    The trick is to keep the revs below 3000 RPM and short shift where possible. The only exception is when screaming up Mt Victoria in 2nd Gear at redline, whilst praying that I do not break a connecting rod in the process.
    P.S My car only has a 77mm piston stroke and a stupidly long rod ratio, so revving the freaking bananas out of the engine would not be that bad (I hope).
    I didnt realise that VW had any 1.6 deisels in the Mk5??
  5. #95
    Jun 2007
    Chatswood, Sydney
    Quote Originally Posted by gtimk5 View Post
    they dont... neither do they have 60L fuel tanks
  6. #96
    Big Al the Butchers' Pal Guest
    My car is petrol. In response to your query, I rechecked my technical information as is stated in my car manual (located in the glovebox).
    My car seems to be the only model contained within that has a 60 litre capacity fuel tank. The rest have 55 litres. Only the 75kW Petrol Engine has a 60 litre tank according to that technical data sub booklet (part of a number of books contained within the overall black folder).
    I re-checked some of my petrol receipts and I have filled more than 55 litres on a number of occasions.
    I will ask the Bug_Racer as he is due to do some maintenance checks on my Golf in the near future, but my manual states 60 litres. If my car is in fact 55 litres, then I will correct my consumption calculations accordingly.
  7. #97
    Sep 2007
    Rowville, Victoria
    Smile
    For what its worth one of my non VW car's hand book says it has a 68 litre usable tank but on occasions I have been known to put 75 litres in it!
    The whole subject of fuel tanks and gauges and their accuracy can be an emotional one. The only way to put it all to rest is drive until the car konks out and refuel to capacity (that's how I found out about the 75 litres above). This is not too good or recommended becuase of the crap picked from the bottom of the tank though.
    Sometimes when the low fuel warning on our Jetta comes on I can fill up and only get 47 lt in and other times 53 lt (taking note to fill up asap when the light 1st came on). In the handbook the guide is that the light comes on at about 48 lt. So give or take it's within limits.
    Cheers to you all.
    BeigeJet
    White MY23 Tiguan 147 TDI Elegance (mine)
    White MY21 Tiguan 147 TDI Elegance (wife)
    Gone - Wheat Beige MY07 Jetta TDI manual
  8. #98
    Jun 2007
    Chatswood, Sydney
    thats ok if the book says 60 then its 60
  9. #99
    Canberra
    If you are interested in fuel economy (or consumption) there is only one way to calculate it with any accuracy (don't believe your VW MFD, they can be more than 15% out) :
    Fill tank to brim, record current odo reading (or set trip meter to zero).
    Drive at least 200 km (any less reduces accuracy).
    Fill tank to brim. Record how far you have driven it and how many litres you put in.
    Divide litres by kms X 100 = fuel consumption in litres per 100km
    Some factors that can affect how much (or little) fuel you use are:
    City driving uses more, hwy driving uses less (usually).
    Faster driving uses more, slower uses less.
    Hard acceleration uses more, gentle uses less.
    Cold engine uses more, warm engine uses less.
    Aircon "on" uses more.
    Roof racks with stuff on uses more (wind drag).
    Towing uses more (wind drag and weight).
    Anticipating lights and stoppages uses less.
    Properly inflated tyres use less (as do narrower tyres).
    Diesels use less than petrol engines (usually).
    I strongly advise against "drafting" (following closely behind another vehicle - too dangerous) or "coasting" (particularly with your engine switched off - that's just plain suicidal).
  10. #100
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Just done my fuel consumption figures manually.
    1st tank. 949km average 5.5/100
    2nd 948km average 5.3/100
    3rd 1216km average 4.7/100
    3rd tank consisted of added 6.5litres $10.00 of fuel from Young servo to get me back to Sydney.
    Most of travelling done on Fwy. use of BP fuel and mostly no aircon.
    Trip to young is down hill returning to Sydney from the Southern highlands.
    My MFD on setting 2 is showing Average of 4.9 which has not been reset
    from day 1 of ownership.
Similar Threads
  1. hi guys new forum member
    By tenji` in forum Mk4 Golf & Bora and New Beetle
    Last Post: 02-08-2006, 09:23 PM
  2. Replies: 12
    Last Post: 23-07-2006, 05:43 PM
  3. Finally got some, sorry guys
    By vinderliker in forum Wheels & Suspension
    Last Post: 11-04-2006, 07:32 PM
