Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 105
Thread: What are you guys getting?
  1. #81
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    and you shall have your answer - albeit an engineering educated diesel head guess.
    there is no need for a diesel engine to use any fuel during an engine braking scenario whatsoever. i used to have a manual switch for the fuel solenoid on my old mk1 gld which cut off fuel completely, and not surprisingly, the engine works just the same without any fuel in that situation as if it has idle fuel.
    it is very likely that the ecu mappings on the new tdi's allow no fuel though during no load operation/above idle speed because this is a sensible way to reduce fuel consumption. there is no engineering reason why this could not be done.
    You made it sound so simple. Thanks.
    Have a round trip to work of 40km.@ mostly 100km/h.
    Oneway is part down hill. Been getting 5.5 and the other 5.1
    Neil.
  2. #82
    May 2006
    Maroubra NSW
    Adding to this- if you are saying your engine is doing 0.5-0.7l/100km at idle- is this while stopped?
    This would be infite litres/100km if you are doing 0 km/h while it is telling you that...
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
  3. #83
    Jul 2006
    South Australia
    You're right Smithy.
    The readout at standstill is actually L/hr not as I quoted originally
    cheers Macca
  4. #84
    homie100968 Guest
    My new TDI DSG Comfortline..
    I havent let my tank run almost empty till today and the tripmeter indicated 777Km, I filled till it was almost running out the filler neck , 47 liters used so gives an average of 6.04L/100km although the trip #2 indicated 6.7L/100km?? Go figure.. I also noted my GPS tells me the speedo is indicating 106Km/hr at an actual 100Km/hr. I run the aircon 100% of the time set to 22Deg as the 30 something outside is somewhat uncomfortable.
    Fuel consumption at standstill is around 1.2L/hr, AC running and 0.9L/hr with it off. Car has 2000Km on the clock. Tinted windows yesterday.. Towbar last week ( Did it my self ) wiring for towbar yet to be completed ( see the thread on the towbar wiring hassles ) So far so good.
  5. #85
    Jun 2007
    Filled up for first time today.
    954km on one tank, put in 53.1 litres.
    I think the tank from memory is 55.
    Trip from central coast to Bowral 230km averaged 5.3 and return trip 4.2
    (MFD)
    Return trip is down hill. no air con and traveling at speeds of 90-110 for
    run in period.
    Filled up with BP. I suspect the dealer did not use bp as I have not seen
    any around there service centre. So will be interesting to see if I can
    improve on economy with bp.
  6. #86
    Gosford Central Coast NSW
    nice numbers - 4.2... hehe
    my mk3 economy keeps improving - i've tinkered so that the turbo is always operational (electronic wastegating) and the low rpm timing retard is disabled...
    that change alone (after 3 tanks) ahs improved the economy from averaging 6.4l/100km to 5.75l/100km.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  7. #87
    Big Al the Butchers' Pal Guest
    Golf V 1.6 Fuel Consumption
    My Golf V 1.6 is used only for travel from Sydney to Hartley, and some occasional running around in Sydney traffic.
    I normally get 950km to a tank and 980 on the odd occasion if I travel too far beyond the fuel light turning on.
    According to my glovebox manual my tank is 60 litres capacity which equates to 6.3 litres per 100km. I use regular unleaded fuel.
    The trick is to keep the revs below 3000 RPM and short shift where possible. The only exception is when screaming up Mt Victoria in 2nd Gear at redline, whilst praying that I do not break a connecting rod in the process.
    P.S My car only has a 77mm piston stroke and a stupidly long rod ratio, so revving the freaking bananas out of the engine would not be that bad (I hope).
  8. #88
    Jun 2007
    Chatswood, Sydney
    on the new gt tdi so far - 8L per 100. something tells me that this n umber isnt going to improve much
    New user account: Mischa
    Have: gt sport tdi, mk2 gti, mk1 3dr
  9. #89
    Aug 2007
    Blue Mountains
    Quote Originally Posted by GermanwithaVdub View Post
    Interesting running in process... Lead foot
    I see I'm not the only one that can't sleep
    SPoddy
    2020 Tiguan 162TSI R-Line
  10. #90
    Jun 2007
    Chatswood, Sydney
    Quote Originally Posted by Spoddy View Post
    hard acceleration but shifting at 3500rpm. im worried what the consumption will be when i can shift at redline
Similar Threads
  1. hi guys new forum member
    By tenji` in forum Mk4 Golf & Bora and New Beetle
    Last Post: 02-08-2006, 09:23 PM
  2. Replies: 12
    Last Post: 23-07-2006, 05:43 PM
  3. Finally got some, sorry guys
    By vinderliker in forum Wheels & Suspension
    Last Post: 11-04-2006, 07:32 PM
