my 2l tdi is at 211km and still going strong
Originally Posted by
kaanage
I'd avoid the 6r 66TDI polo due to the DPF issues (frequent regens / higher than expected fuel consumption) when used in city driving.
The Golf models are great if you want more space than a Polo but will cost more (obviously) so it's up to you to weigh up this.
The 77 and Bluemotion will feel VERY slow vs the 103 Mk V and VI. The MkVI models will be MUCH smoother (petrol-like?) than the MkV and 9N3 Polo (CR vs PD) but will have DPFs that could be a long term expense.
The Pumpe Duse motors are well and truly proven to be rock solid reliable aside from cam bearing wear in VERY high mileage models except for the 125kW version fitted to the GT MkV Golf (+ Passats and Audis) which have injector failures. A couple of the 103kW PD owners have also reported the same failure but this seem atypical.
The 6-speed DSG fitted to the MkVI 103 is a well proven component too unless you are unlucky and get one with troublesome mechantronics (shift control system).
We have a 9N3 TDi and a MkVI 103 and are very happy with both (especially since I had the 9N3 remapped with a Viezu V-Switch).
Hope this helps.
Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
