TDI or 1.6 Petrol?
My advice is spend the bit extra and get the TDI. If you want to get a manual, Check for recall code "35a7" on the chassis below the top drivers door hinge. That means it's had the gearbox oil change or even new syncro's/balk rings etc.. Good sign. I had to get that done on my '07. Check for notchyness into 2nd gear if it hasn't got the sticker.
Apparently on the '06 Caddy's they had faulty compressors that failed around 100k? Not sure about the details, but something worth investigation. Hopefully someone can chime in on that?
Other than that i haven't had an issue with mine.. Been smooooooth sailing. *Touches wood..*![]()
