Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Warming up a diesel?
    Nov 2007
    WA, Perth
    Hi all
    Tried searching the forums to see if there's anything on this but there seems to be none.
    What's your take on warming up diesel engines before going off? A search on google says that it's not necessary- just drive but don't rev it too much and the engine will warm up with your driving... apparently idle warm ups don't help anything.
    what do you think about this and are there any mechanics who can verify anything? i'm not a carhead so i don't know any better.. my mechanic told me to always warm up idle for 5 minutes with my 1994 Golf 3 GL.. but his specialization is jap cars.. don't know if there's much of a difference with jap/euro..
    Logzy Guest
    Start car, idle for 10 seconds, drive.
    Idling is not good for the car and will not warm it up.
    The 2.0 TDI's they say to drive and rev to 2500 (no more, no less) when cold and then 3000 when temp is on 2 white marks, then whatever i guess once its fully warm.
    The reason for this is to stop the VNT cloggin with soot etc.
    Gosford Central Coast NSW
    this is a good question... it does depend on a few things.
    for the new tdi owners, then what logzy has said would be sensible.
    for drivers of older cars, you need to keep some things in mind:
    - if you have a turbocharger fitted to your engine, it isn't nice to work it hard while the engine (hence oil) is cold. keep off the pedal until the temperature is warm so that you do not incur excess wear of turbocharger bearings. - likewise, if you stop after some serious driving, allow the car to idle for a minute so that the turbocharger may cool down, also to save the bearings.
    - if there is no turbocharger, the same applies but the main care should be taken with not using high rev's until the oil is warm.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Nov 2007
    Question then, mainly for gldgti.... new tdi's also have a turbocharger yes? so wouldn't same apply for the turbo bearings also on the newer cars???
    Quote Originally Posted by TDI Dude View Post
    technically, yes.
    if i owned a new TDi, thats how i'd drive it, and cool it down also. however, i did not say this at the risk of being grilled by people who know better.
    also note, i believe that for reasons of "user practicality", VW intend the high grade oil and fine tolerance bearings to eliminate the "need" for this special treatment - joe bloggs does not want to buy a diesel car if he has to treat it differently from any others...
    but, as an engineer, i know it to be fact that if you treat your turbocharger well by letting the bearings cool slowly with lubrication, it will certainly last longer.
    '99 A4 Quattro 1.8T
    Nov 2007
    Thanks for that and I wasnt 'grilling' just asking as there seems to be 1,000 theories about how to treat a diesel these days. I'm a little old school as I learnt about cars by tinkering on a HJ Kingswood 202 and that you had to look after especially in winter (warming up etc) And thanks again gldgti for your answer to my question.. appreciated
    Nov 2007
    WA, Perth
    hmmm... so we technically should warm it up for a while- say a minute? and also then cool it down? how do you cool it down- just by idling?
    sorry never had a diesel before
    its not you i'm worried about... hehe
    '99 A4 Quattro 1.8T
    Quote Originally Posted by en13 View Post
    when you drive fast, and you produce lots of boost, the exhasut gas temperature goes right up. this makes the turbine very hot, which then soaks through into the turbocharger bearings.
    while the engine is running, you're ok because the oil keeps pumping through the bearings. but if you have been hard at it, and you stop the engine, the oil flow stops but the heat saoks through the turbine and into the bearings. this makes them hotter than ususal. this puts undue stress on the bearings and shortens theire life.
    by allowing a no load scenario, like idleing, you have a period of normal oil flow, and low heat production, allowing the turbocharger temperature to stabilise before cutting off the oil supply. this means that when the engine cools down after shutdown, the bearing will not become any hotter than it was before, and is happy
    '99 A4 Quattro 1.8T
    Nov 2007
    Well hang on then give me 5 mins and I'll turn then!!!!
