Results 21 to 30 of 33
Thread: VW Provent kits in progress.
  1. #21
    Oct 2009
    Como, WA
    Quote Originally Posted by cogdoc View Post
    Seems there is either the heat prone bunnings stuff, or way too thick serious stuff, and little inbetween.
    Well I suppose if your Pirtek bro can't help it's not looking too promising at this stage. What are the specs of the hose you're looking for? ID/OD, max working pressure, min bend radius, temperature range.
    MY10 Golf MkVI 103TDI United Grey
  2. #22
    Gosford Central Coast NSW
    Cog, have you looked into normal old reinforced rubber hose? Rubber is our friend. Its hard going getting any plastic hose that will do what you want, but a local rubber hose producer like Grommmet might be able to sell you 19mm reinforced rubber hose by the meter. You can use straight pieces of hose and join them with solid plumbing style bends - 45's and 90's as required. you unly need to use irrigation style ring clamps since there is basically no pressure inside the hoses.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  3. #23
    Adelaide hills, SA
    Or he could use copper or aluminium pipe (paint it black) and use just short pieces of silicone hose to make the joints.
  4. #24
    Oct 2009
    Como, WA
    How about silicone hose? Wouldn't it be more durable and temperature resistant? http://www.txs.com.au/silicon/straight.htm
  5. #25
    Quote Originally Posted by Frankenstrat View Post
    yes, silicone hose is more durable and heat resistant - but its also, literally, about 12 times the price. silicone hose is also WAY overkill for the application.
    '99 A4 Quattro 1.8T
  6. #26
    Jan 2008
    Sunshine Coast
    I have found hose!
    And yep it's a thin walled twin layer silicon. Purosil, from Qld Diesel Service. Even our local huge hose world had nothing suitable, but they put me onto the diesel place. hey were very helpful, and I had a boner walking around the shop.
    Rubber will go hard and break down, plus it's not flexible enough for the application. It's simply not listed anywhere as being suitable for fuel / oil. Needs to be done right!
    So it comes in 1" or a much more svelt 3/4", which will clamp straight on the VW fittings, and easily stretch to the 1" provent / VW return fittings. It also comes in blue, blue or blue. Buy Aydan is right, it's friggen dear at $40-$60 per meter.
    I have a meter of each in the boot right now, and will have a play over the weekend. I'm excited to finally have a proper answer for my own Provent install let alone any form of "kit", which I'm still wary of the legalities of.
    Still, it's a win for any DIY Provent installs out there, and I'm sure you can get the same silicon hose off e-bay for about half the prices I paid today.
  7. #27
    Rubber will go hard and break down, plus it's not flexible enough for the application, and it's not listed anywhere as being suitable for fuel / oil. Needs to be done right!
    Cog, the standard breather piping on every car i've ever owned has been rubber..... even the boost piping on some OEM cars is rubber (older golfs, pugs, mercs....).
    just saying, it works
    good work finding some hose you like though.
    '99 A4 Quattro 1.8T
  8. #28
    Oct 2009
    Como, WA
    I have found hose!
    Excellent news!
    Too much information!!!
  9. #29
    Apr 2009
    Berwick, Victoria
    Hi,
    been following this since first post? I have a GT SPORT TDI and are interested, problem is I'm in Melbourne (But do visit Brisbaine). Do you have a ball park price in mind? and would be interested in more detail of the filtration method. Hope this goes well for you.
    Re: legalitys, in Australia and most advanced countrys. It is illeagal to sign you'r rites away. Tested in court, individual rites stand, Inshurance companys, etc use this as a tool to minimise litagation. It probly would be best as a "do it you'r self kit". Warrent the item, not the car or fitting. Dependant on pollution laws, etc. Note the item suitable for off road use only. Though every one will know it's intended use.
    PS: You had a section referring to a DPF delite kit. Would be very interested in this but it's a bit pricey for me. Is it likley to latter get a kit to replace the DPF section only, rather than the complite exhaust. I have had no DPF problems, recently I used a blanking plate to block recirculation to the inlet. All was OK, till a day latter. 18,000Km and the first time my warning light came on. Removed plate, light still remained. After a good run, next day. The light went out. I expect this was coincidene and only was in regen mode? I've only driven the car in city traffic once, but noted at the time of fitting the plate, my inlet was gunked up with carbon.
  10. #30
    Adelaide hills, SA
    Quote Originally Posted by davidno64 View Post
    Because the emissions were out of range, after you put it back and driven for while, 1/2 hour trip where the emissions are in range and the ECM light will turn OFF automatically.
    There is a product that clean the Inlet tract - MOTORCRAFT Combustion chamber and Induction system cleaner (suitable for petrol,diesel and LPG angines), Motortraders sell it.
