Results 11 to 20 of 27
Thread: VW Diesel PD Piezo Injector. (also for non piezo injectors)
    Oct 2010
    No extended warranty, ive serviced it myself since I bought it at 70000k and hadn't even filled on the logbook.
    I'll scan the info they gave me and upload it tomorrow
    Edit. Scan added.
    Edit2.
    There is a VW TPI for this - 2026885/5 (23 Nov 2011)
    "Engine: does not start, engine warning light on, entries logged"
    Applies to BMA, BKP, BVE, BWV, BMR, BUZ, BMN engines with "03G 130 073 D" or "03G 130 073 M" injectors
    "Technical background
    1. An incorrect pump-injector unit prevents the control of all pump injector units.
    2. Incorrect diagnosis of the intact main relay because of an incorrect pump-injector unit.
    3. Engine control unit does not work."
    "The following entries can be logged in the engine control unit:
    • P2146 injection valve(s) supply A, disruption
    • P1040 injection valve(s) supply A, electric complaint in circuit
    • P2147 injection valve(s) supply A, short circuit to earth
    The following entries may also be logged:
    • P1517 main relay -J271 electric complaint in circuit
    • P1388 control unit incorrect
    • P1570 engine control unit locked"
    "To prevent a future contact resistance, replace also the wiring loom for the pump injector units in the cylinder head according to the repair manual/parts catalogue."
    If after replacing the injectors the engine doesn't start then -
    "If the production date of the engine control unit is before 01.04.2008, replace the engine control unit according to the repair manual/parts catalogue."
    Replacement parts:
    03G 130 073 SX - Pump-injector unit 88 kW - 103 kW
    03G 130 073 TX - Pump-injector unit 88 120 kW -125 kW
    Golf GT Sport TDI
    Jan 2008
    Sunshine Coast
    Best information in the flipping WORLD mate, well done, you are to be congratulated. You've finally confirmed that if your car meets the free replacement guidelines, you should be getting it done free of charge. Not sure when they finally made this official, and I guess if you have paid to date, you'd have grounds to be passing a letter to VWA seeking compensation based on this. You'd have to ensure your car meets the guidelines though, might have to take the rocker cover off and have a look at the injector details.
    Again, great work, you need to put this on the Facebook page, and get the accolades.
    Oct 2010
    Quote Originally Posted by Greg Roles View Post
    Word. Get on this if you have been out of pocket for the problem!
    Nah you go for it mate, I'm not worries about accolades.
    Golf GT Sport TDI
    Apr 2008
    Wa hey!
    Nice work Jarred. I'm not surprised they have behaved in this way but it's good to see nonetheless.
    Jan 2008
    Sunshine Coast
    I have 03G 130 073M injectors ( can just read on the bottom right of pic ), so it seems sooner or later my TDI will probably conk out...but it will be interesting to see if my heavily modified TDI is still covered by the above....
    Apr 2008
    I've never been convinced it's the injector unit but the loom that kills them.
    Time will tell on that for you but here's hoping.
    Jan 2008
    Sunshine Coast
    I've heard overall that the loom is simply replaced as the oil hardened plugs are real easy to break, heck I sure did break my old ones when putting in the new Audi loom!
    Melbourne's NE
    Been a while but thought I'd chime in.
    Last Thursday on Hume, just before Wallan exit "Engine failure", no warning whatsoever, no power steering, no brakes, managed to pull over without incident.
    car: Passat wagon, 125 kW, 4 years 2 months old
    odo: 84,220
    Towed to Wallan, RACV guy thought I'd run out of fuel.
    Towed to Bayford VW in Cooper St, Epping next morning. Received call that care had been received, but busy and long weekend.
    Received call Wednesday morning, injectors replaced (incl. loom), under warranty. Only charge was for performing the diagnostic ($130), happy with that. Had faulty park brake switch replaced as well but had to pay for that.
    Picked up car today, cleaned inside and outside, drives like a dream.
    Very happy with the customer service, will take my car there for the servicing in the future.
    Let's hope it's not going to happen again.
    Michael
    MY08 125 kW TDI Wagon
    PE Black, Sunroof, iPod
    MY09 CR TDI Eos 6-speed manual
    Candy White, black leather, Sports suspension with 18" Chicagos
    Feb 2008
    Townsville QLD
    I think you will be OK. When mine died the reason quoted was "Carried out TPI. Found the current part number on the injectors is incorrect". They were replaced with part number VW03G130073TX which is what you have already. See also JAZD 's 09/02/12 post last line.
    Was advised that VW are now covering injectors and harness under warranty for 7 years in lieu of the standard 3 years.
    Granite Passat sedan TDI (125kw), DSG, beige leather
    Candy White Polo 6R, 66TDI, DSG, no options
    Oct 2010
    Just a heads up it seems the X on the end of the part number means it is a refurbished part. Thats just great!
    VW and Audi part numbers system explained in ETKA
    MY09 White dials for 2.0TDI what part number?
    The two M/MX parts are listed in ETKA as alternatives to each other and the MX part has a # (hash) next to it which I assume means refurb.
    Golf GT Sport TDI
