Results 1 to 5 of 5
Thread: Vibration
    Oct 2005
    Vibration
    Can anyone confirm for me that a vibration I feel through the steering wheel of my GLD at idle and stationary is likely to be engine mounts?
    2008 Golf V 2.0TDI
    1973 Superbug L
    1969 Karmann Ghia
    1954 Oval Beetle
    Previously: Numerous Golfs & numerous Beetles
    imported_brackie Guest
    Get out the wallet
    Almost certainly. You can check them individually and replace those that are suspect, or just replace the whole lot. I'd recommend the latter. She'll probably never idle as smoothly as a petrol model, but hey!! It's a diesel! They way you can check is to put a trolley jack under the motor with a block of rubber on it. Just take the weight of the motor/transaxle (be careful) and if the vibration goes away you can suspect the mounts.
    We use 4WD motor bikes on the farm and we bought a Polaris with a Yanmar diesel. It pulled like a schoolboy and ran for ever on a tank of diesel. But eventually it literally shook itself to bits. Our 90hp Deutz tractor broke an oil line yesterday, again from vibration. That's diesels!
    Camden, Sydney
    Its usually the one on the timing belt end which is a swine to change, or the one at the back on the backside of the gearbox.
    Oct 2005
    Thanks guys.
    I'm pretty used to diesels too - country born and bred....
    2008 Golf V 2.0TDI
    1973 Superbug L
    1969 Karmann Ghia
    1954 Oval Beetle
    Jul 2005
    Yarra Junction, Melbourne.
    Having just replaced the engine mount at the timing belt end I can report that it fixed most of the vibration through the car and is indeed a swine to change.
    '03 LT35
    '89 Syncro Kombi
Similar Threads
  1. Front End Vibration
    By Anonymous in forum Mk3 Golf & Vento
    Last Post: 11-07-2005, 10:34 PM
