Results 1 to 4 of 4
Thread: Variable Vane turbo control
    Aug 2009
    Brisbane Sth
    Just wondering if there is a manual method to control variable vanes on a turbo if the engine has a pump dusche IP or if with a mechanical pump i have to stick to old style turbo? I am assuming the V turbo is driven by the computer?
    any thoughts appreciated
    Spark ignition is a threatened species
    Biodiesel is the best emission control money cant buy
    MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
    Gosford Central Coast NSW
    electronic control:
    Micro controlled VNT project
    mechanical control:
    VNT Vanagon
    I think VNT's are a good solution, but its just a tad more work to get one in and running well. you will, however, reap the benefits. After having fooled around with the large T3 on my 1.9, I am personally tired of llllaaaaaaaaaaaaaaaG. I say go for it, - and, if you find a good source of OEM second hand VNT's, let me know
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Aug 2009
    Brisbane Sth
    Ok sorry I took so long to respond. Looked at both intently and I might just go old style to get it going. looks like it might take a little mucking around to make the mechanical harnesss. are the manifolds the same would a vnt fit in the same slot later on?
    some of the vnt's have the turbine housing cast as part of the manifold (actually, most). There are a couple that aren't, but are 1) sought after - and 2) rarer to begin with. So, no, the manifolds arent really the same.
    Good luck
    '99 A4 Quattro 1.8T
