Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Unusual sound from engine at around 50-80km/h on Golf VI 103TDI
  1. #21
    Nov 2007
    khamtran, is your car a GT? I thought the oem tyres were hankooks (on normal tdi's)
    I'm pretty sure GT's had continentals not Bridgestones, well mine did anyway.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  2. #22
    Apr 2008
    +1 for Conti's but in later times the RE050 seems to be quite common.
  3. #23
    Jan 2010
    Melbourne, VIC
    funny actually, this is exactly the problem i've been having with my mk3 golf. I got a set of pirrelli p6000 on it last year around april, and now they are about 3/4 worn and the noisiest tyres i've ever had. they are all "scallopped" aswell.
    I always run my tyres at a bit over the recommended pressure (always get better handling, life and fuel economy) but these tires just seem to wear badly. still, i've got 45,000 km from them.
    I also run my tyres slightly over the recommended pressure by about by 2-3 psi.
    Mine's not a GT but a 103TDI with sports pack which came with Potenza RE050 17" 225x45 rubber and sports suspension.
    Black Golf VI 103TDI Manual with Sports Pack
  4. #24
    Nov 2007
    Sounds like an easy fix anyhow and luckily isn't a mechanical issue.
  5. #25
    Gosford Central Coast NSW
    Quote Originally Posted by khamtran View Post
    ahh yah sports pack
    my old work neighbour got a really early tdi with the sports pack, but it had hankooks... being an early car they probably put whatever on it.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
