Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Unleaded into Diesel Passat B6 am I screwed.
    Quote Originally Posted by OilBurna View Post
    All checked running fine
    Good news. I bet you're relieved.
    Dec 2007
    ivanhoe vic
    Yes thanks apart from the bill lol drained tank full flush and new fuel filter engine seems much smoother now which is weird.
    B6 Passat Wagon No KESSY
    Yes and also the cost of a tank of "wasted" fuel.
    Erskineville, NSW
    Would have decarboned it a bit?
    Way, way back (pre-tdi days) we used to throw a liter (about 2% of the mix) of petrol in the workshop Toyota Hilux diesel (circa 1979?) because the boss reckoned a little bit of petrol or metho was beneficial for starting. Used to throw plenty of other rubbish in the tank too - it was a very agricultural engine.
    I know almost nothing about diesels (still) & this isn't something I'd recomend as it appeared to make no difference.
    Gosford Central Coast NSW
    Quote Originally Posted by wai View Post
    On damage to you fuel system, it depends. Diesel acts as a lubricant for the high pressure furl pump, and so, while everything may appear OK, damage could well have been done. A friend of mine had a Mazda CX9 Diesel and his daughter did much the same thing as you did. He did not even get off the forecourt because it was running so rough. It ended up costing him over $3,000 in repairs to the engine and fuel system.
    The PD engine doesn't have a high pressure fuel pump. You are thinking of the CR engines. The PD engine has a low pressure fuel pump and it has a plunger in each injector for the high pressure.
    A PD TDI passat is not a CX-9 (and thank goodness for the OP)
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dec 2007
    ivanhoe vic
    Does that help or hinder in this case?
    Helps.... the piston pumps do relatively small movment to generate the high pressure, so it would take a lot of running on petrol to damage the injectors from wear.
    '99 A4 Quattro 1.8T
    Dec 2007
    ivanhoe vic
    Ok thanks...
    Aug 2012
    Perth WA
    Fits ok amalgam?
    I use one of these and it works as advertise. Even tried to fit an ULP nozzle and it prevented insertion.
    http://www.racq.com.au/__data/assets...ay-2012-v2.pdf
    Very happy and would recommend it without reservation.
