Hi Cogs,
yeh the Polo has a small side mount IC, however Ive got a Gallant VR4 IC that should hopefully sit quite nicely infront of the radiator without modding the front bar
ill give you a holla about all those elbows and stuff mate, still gotta get the IC pressure tested yet!
i dont see the point in a DP on this size turbo, however Ill do a high flow cat and muffler just to free it up a bit more.... Have also done a SEAT intake which made power delivery smoother.
ive never claimed it was earth shattering quick, nore have i claimed anywhere in this thread that i want a world beater or a drag racer (i'd get a old commo V8 for that!) I want to take it to some sprint days and enjoy it legally.
whats the club?!!
IIRC some of the VAG cars in the UK come with up to 150hp out of their "factory standard" 1.9 TDIs, presumably with bigger VNT turbos, bigger injectors and who knows what else.
One thing to watch out for if you bump up the power is the Dual Mass Flywheel (DMF). They are prone to failure on 1.9s that are only remapped, let alone serious modifications. Mind you, the problem seems to be more at the 1400-1600rpm mark, and you mightn't be spending much time at those revs if you are after "big powa".
The Briskoda site might have some more info if you care to look (there's several threads about converting DMFs to Single Mass Flywheels).
go the vnt17 (from a GT) or a vnt20 (even bigger). but dont whinge if your warranty is voided![]()
2x Caddy, 1x Ducato
Golfie, by club, I'm referring to the USA site TDI club. It's mainly all about the 1.9 TDI motor, a wealth of info for you.
If you can give me your engine code from your owners manual, I can look up your turbo on Elsawin. My Erwin manuals may have some info for you too, I'll have a look.
Find the sticker on the inside cover of section 1/1 Passenger vehicles Service schedule. As an example mine says"
Golf 2.0
125kw fTDI M6F
BMN ( engine )
LA7T ( colour )
