Results 11 to 20 of 27
Thread: Thinking of a diesel. Questions.
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by doc View Post
    Might have to convince the wife into learning to drive a manual. 2 hopes with that.
    BWAHHAHAHAHA. I feel your pain, doc! You'd think that with all their torque, you wouldn't need an auto for a diesel but my wife is the same
    At least the 6 speed DSG itself is strong, unlike the 7 speed dry clutch unit being recalled around the world (excluding Australia)
    Resident grumpy old fart
    Dec 2009
    Melb. (SE), VIC
    Quote Originally Posted by Greg Roles View Post
    If you are careful it's actually pretty rare to get diesel on your hands at the servo, if I do, , I just wipe it on my pants, usually business attire. Bit of man cologne.
    Those white stains aren't from diesel Greg.
    Apr 2008
    Bundoora Victoria
    I really appreciate the input from all of you.
    Well I bit the bullet today and ended up buying a late 2006 with 98000 on the clock. It has a service history in the books and realize it will need a cam belt soon.....but it was too good a deal to pass up. It's in excellent condition and I couldn't fault it. I did notice that the diesel is different on takeoff but wasn't too bad. I won't be driving it much anyway.
    I generally do my own services but can't follow the VW oil specs of 502/504 etc. What specs and viscosity do I use for this car. I won't be collecting it until about Wednesday (so I don't have any info) but always change all the fluids and filters when I buy a car. That way I know it's all good.
    cheers...doc
    Apr 2012
    I wonder if the 23H9 recall campaign effects this model (Year wise its right in ther)
    Apr 2008
    Bundoora Victoria
    I certainly hope not. I haven't had a good look at them but all the invoices are in with the service books. It's been serviced by VW all it's life. The engine prefix is BKD. I was led to believe that it was more than likely BKP or BMR. How do I tell?
    Here's hoping.
    cheers.
    PS. I found the info about the oil.
    Nov 2007
    Quote Originally Posted by Dr freedom View Post
    Pretty certain it was only the 125Kw engined TDi's that are fitted with the Siemens injectors so that would include the GT and the Passats, not Jetta's. They were fitted with the 104kw TDi engine and have Bosch injectors that are not part of the recall. You can always ring the VW dealer, quote your VIN number and see if its eligible for the campaign.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Gosford Central Coast NSW
    I keep a small bottle on the shelf at home for special occasions.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2008
    Sunshine Coast
    Only the 125kw MKV diesels were affected. Jetta is fine. Run it on good name brand diesel, put the odd bottle of Fuel Doctor from supercheap through it, and it will be quite trouble free. Castrol has a VW specific oil that is 504, and if you look at most bottles at say supercheap, they will list "meets or exceeds VW 504" etc. Pick a brand and stick with it. I run Penrite Enviro, but have to look for a higher grade due to my DPF ( that you donlt have! )
    Also get your oil filters from VW direct, half the cost of the Ryco at Supercheap! Oh and you will need a 32mm socket to pull the oil cap off from the front of the engine from the TOP. It's not a spin on, nor accessed from the bottom - that's an oil cooler down there!
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by getjet View Post
    Yep that's sweat, goes with the faint diesel smell, to differentiate me from sensitive new age men.
    Dec 2007
    ivanhoe vic
    I wouldn't be so sure the 103kw TDI passats from 06 are affected by the recall, mine has the sticker as a check as my injectors had been previously replaced under extended warranty. My understanding is that it covers the 103kw and 125kw PD engines.
    B6 Passat Wagon No KESSY
