you can use your speadsheets to calculate a more useable flow number (such as lb/min or m^3/sec) and use that along with your boost MAP data to plot points on a compressor map for your turbo. this will atleast tell you if the turbocharger is in the surge range.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
