to get the dash panel off, reach behind and unclip the light switch unit, dash panel wiring harness and brakelight/park brake light cluster. unscrew speedometer cable from the back of the speedo. if you have a radio installed in the factory position, remove it. now remove the hazard light swith, and rear demister switch, and anything else clipped to the dash panel insert. (your heater control lighting is a single globe on the right of the heater control cluster which has an eatch and +12V wire connected to it - it's highly likely one of these wires has dropped off.
once your radio is removed, look inside the cavity behind the radio to the right and up. you will find your dash panel insert in mounted against a steel dash mounting bracket here which is connected to the rest of the dash. there is one single screw and washer at this point, and with a short screwdriver you should be able to undo this screw. once done, remove the heater control knobs and blower fan control knob.
now you shold be able to pull the dash panel insert out of the dash to work on. it may require a small amount for force to get it free of your dash, so be mindful of ths when removing it as not everyones dash panels are in good condition it may be necessary to be very careful so you dont break parts of it off!
good luck.
aydan
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
