Results 1 to 10 of 27
Thread: TDI engine for Golfs
    May 2006
    Maroubra NSW
    Let me get this straight..
    Ok, let me get this straight. I'm seriously considering one of those 1z TDI's that loon is selling.
    I'm concerned that if i get one, i will be biting off more than i can chew..
    Does anyone know exactly how much ECU gear is in these things? And how much of an engine management wizz i have to be to get the damn thing started?
    Let's start from the start. The block is theoretically the same size as the standard 8V mk1 engine. right?
    Am i likely to need any additional engine cooling or pipework?
    Will the diesel starter off the CK engine (1.5IDI) work on this one? (i can't personally see why not, given it has a lower compression ratio).
    Now, this engine is not to be confused with the AAZ engine, which is an IDI donk.
    Can anyone see any forseeable issues?
    Am i barking up the wrong tree here?
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    Jun 2007
    Eastern Suburbs Melbourne
    from what i've heard, it's pretty simple. cause its all mechanical (the pump) just a couple of wires, some plumbing (stock stuff'lll do) and hey presto. obviously a litttle more complex but yea.
    I was seriously looking down this path. but the cost was too much for me.
    i like volkswagens
    Camden, Sydney
    Aydan would be the one to ask. I`m not a Diesel Guru. However, when I spoke to him about it, he seemed to think, just a wire to the pump and a simple blow through turbo.
    I have 2 engines on the water, one is sold to Mollins, deposit taken and there is one left. Dont leave it too long, they are hard to get.
    Gosford Central Coast NSW
    smithy, got to www.vwdiesel.net and search around there. you'll find all the info you need.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Unhappy
    ok guys, i dont know much about engine cade but i am guess these are the 130 or 150 bhp ones??? like what are in the GT TDI mk4's???
    if so then i bring bad news....fitting one of these is really really hard (i am not saying it cant be done...it can) that why not many people have done it. it a far easier and cheaper it fit a 20v T
    I think you need to change fuel tank, lines. there is something about the fuel being hot so there is other poblems there....that all i can remember at the mo. I am sure you will find out more on the net. try ClubGTI.com/forum
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Nov 2005
    newcastle
    good news
    Quote Originally Posted by velly_16v_cab View Post
    velly is right when he says the mk4 engine is tricky ... the mk4 and mk5 TDI engines are very different, with computers and wizzbang stuff... i looked into this briefly but is a bit tricky
    however, this engine came in mk3 diesels from 94 to about 96 i think
    they are pretty much the same block as the AAZ 1.9 T IDI which is not that different to the good old 1.5 IDI. Cooling is similar, fuel lines is all the same as the AAZ... smithy, your petrol tank with modified lines for your diesel should be fine...
    a lot of guys in the states run this 1Z engine as an "M-TDI" setup (mechanical TDI setup).. you basically remove/bypass all the electronic sensors and stuff and set it up like the good old IDI's.
    I cant wait to get my engine.. when I do ill document my conversion well so others may enjoy diesel goodness..
    cheers
    mike
    TDI mk1 on the road!!
    May 2006
    Maroubra NSW
    Mike, i assume you have had the down low on the 1z engines before...
    What are your plans with the diesel, i don't care about what yu're going to do to make it go faster, but what are you going to do to get it going?
    I assume these engines will come with an ECU.
    On this assumption, i then assume that the ECU won't give me any problems with having to get coded keys or any stuff like all the new car freaks have troubles with...
    Can you shed some light on this, or are you going to run it as an M-tdi (i reckon this is dodgy, taking an AAZ pump and putting 1Z internals in it...)
    I'm getting into a flutter, because if it aint gunna work out, then i'll rebuild the 1.5 IDI and go back to my 37kW thinking...
