Well, I finally tried it and it made surprisingly little difference in the way the car felt except from about 1400rpm to 2300rpm where the engin felt very flat compared to usual.
It made the engine throw a warning light after I revved it out for a bit (no other effect, though) but that went away after I reconnected the vacuum line and drove about for a while.
Resident grumpy old fart
