Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Superchips Bluefin, once bitten twice stoked!
    Erskineville, NSW
    If you are happy with the Bluefin then perhaps its not worth the trouble. In my case, i wasn't happy and they couldn't get the tune right - so i moved on to the other option i was considering.
    just worked it out. Would have to spend about AUD450 on the reset plus the original cost of the unit less whatever premium over $450 I get when I sell. Not worth it.
    Feb 2014
    Central Vic
    Thanks for that fellas, my priority is fuel efficiency and drivability and both are down here.
    I'll probably go the DNA route now.
    thanks again.
    Dave
    Quote Originally Posted by Ryeman View Post
    thanks again.
    Dave
    The Octy with DNA tune would still return under 5L per 100km on the freeway. Was ever so slightly better on fuel after the tune, providing your not to heavy footed on the go pedal.
    In terms of driveability, all tunes are still retain smooth operation. Obviously if you put your foot down you will get everything in one hit, but driving around normally with light throttle there is no difference between tuned and not tuned really.
    Bowral, NSW
    thanks again.
    Dave
    Your ECU will need unlocking.
    I have the Revo stage 2, economy didn't change but my boot did
    You'll wonder why you didn't do it before!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Aug 2007
    Quote Originally Posted by Mysticality View Post
    Did you make it home ok ? didn't hear??
    Jmac
    Alba European
    I have to give two thumbs up for Superchips customer service.
    They also have a very responsive rep in Melbourne & New Zealand.
    And right near you too btw
    Erskineville, NSW
    Quote Originally Posted by parso_rex View Post
    Who dat? You? PM me.
    You're over at Miranda? Been thinking about contacting you for advice & check-over. I'm thinking my A/Fs & timing pull are going off course. Need an objective opinion.
    Yep, just over the bridge from you too
    AFR's being off would be unlikely as everything is pretty much locked. There is limp modes of course but that would be due to a hardware issue. Timing values vary depending on the level of tune but these are fixed too
    Its all easily logged of course and I can do this anytime pretty much, if I'm not busy I don't bother charging either
    Erskineville, NSW
    PM me your number. It just doesn't seem as efficient as what it used to be. Maybe I'm just too used to it. Needs a fresh set of eyes.
