Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Superchips Bluefin on a Mk5 GT Sport TDI
    Oct 2010
    Cant comment on the quietness as my car is a TDI, it was unchanged though as far as I could tell.
    Can definitely recommend Bluefin as a cheaper alternative, much easier too.
    The Bluefin stores two maps, a stock and a remapped. You should be able to change the stock map stored on it to an upgraded map from the dealer without too much hastle. I dont think Superchips would issue another remap for the upgraded map though it would likely stay the same.
    Golf GT Sport TDI
    Jan 2011
    Melb, VIC
    Quote Originally Posted by jazd View Post
    I'd have to agree. If the dealer is just modifying your stock map then there are no engine changes so the Superchips map is just as relevant as it was previously.
    Nov 2007
    Quote Originally Posted by ctan View Post
    Hi guys, I've been really interested in bluefin as an alternative to APR which is so expensive. Is it really that easy to put it back to stock and then back to bluefin using the device as described in the manual? How long does it take? Also is it much noisier after the upgrade? I beg to be different, but I love the quietness of my 118 TSI and would rather it remain that way after the upgrade. This option appeals to me because it is less than half the price of APR and the fact that it is DIY. I you revert back to stock when you take it to VW dealer for service and the dealer upgrades the stock ECU, do you back up the revised stock VW ECU again to the bluefin device? If you do, then do you need to send this again to Superchips for a new revision of the superchip product? I hope you understand my question.
    Like mentioned the bluefin controller stores the original VW setting and the modified one. Changing it over takes about 10 minutes and its dead easy - you just plug the unit into your diagnostics port and select either stock or modified on the menu. I had a new ECU installed in mine by VW so the original map on my unit was worthless - I simply explained this to superchips and they reset it all and allowed me to install the new VW map into the controller and then again did a new performance map based on this new map. Didn't cost me anything.
    I really don't see the benefit of spending anymore on more expensive chips.
    I doubt very much the car would get louder - if they adjsut the boost level you may hear an increase in induction noise but that would be about all. Mine didn't sound any different after.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Oct 2010
    Melbourne, VIC
    Other remap companies will reissue a new map (or maps in my case) if the original is updated during a service so I would ask Superchips about this. They may wish to incorporate some of the new mapping in their remap(s) - you would just have to redownload the updated 'stock' map and send it back to the tuning company.
    And I agree that it certainly pays to look around at all the (reputable) alternatives before choosing a remap if you aren't going with a "Stage 2" type remap and hardware package.
