Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: stock boost levels for 1.9 TDI ?
    Apr 2009
    Hi all.
    can someone please tell me what the factory boost level is for the 1.9 PD TDI mk5 Golf ?
    i read somewhere that it's 2.1 bar ? that sounds a little high to me.
    that's 30.87 psi. that sounds like lots for a stocker.....(my first experience with a diesel, so i have no idea what's normal)
    im about to buy a boost gauge, and wanna make sure i get one that has the correct range.
    i plan to have the ecu flash tuned at a later date too, so some leeway will be needed, as i don't want to be replacing the gauge in the future.
    can anyone shed some light ?
    Jason.
    05 Golf 1.9 TDI comfortline DSG
    I've heard its around 18-20?
    I need to buy a boost guage aswell and check it out, I too am curious!
    Adelaide hills, SA
    Quote Originally Posted by 85turbo View Post
    Hi all.
    Jason.
    From 0.9 Bar @ idle up to 2.1 Bar
    Apr 2009
    Thanks Transporter.
    2.1bar! That's impressive.
    I'll head out on the weekend and pick up a 35psi gauge.
    Hopefully that's enough to cover any changes that are made
    once I eventually get round to the re flash.
    Jason.
    Apr 2009
    im learning lots about this little diesel.
    being my first oiler and all.... it certainly wont be my last that's for sure.....
    Jason.
    Jan 2008
    Sunshine Coast
    Just for the record, if you run the sender from the inlet manifold, to get true pressure rather than straight out of the turbo for a feel good reading, my stock GT TDI runs 23-24psi maxed. Looks a bit silly on my 0-60psi gauge....for now.
    Apr 2009
    i plan to tap the pipe after the intercooler, and before the inlet.
    so this should take into any pressure drop across the cooler.
    Jason.
    Mar 2009
    moonee ponds oct 2009
    Boost
    Hi,
    2.1 bar is absolute pressure which is atmospheric air pressure + pressure generated by turbo.
    Atmospheric is around 1.0 bar depending on height over sea level.
    Hope this helps?
    Hi all.
    Jason.
    Apr 2009
    so what your saving is that i will only see 16.17psi on the gauge (ie:1.1 bar) ?
    1 bar is roughly equal to 14.7 psi, or like you say one atmosphere.
    This is starting to get confusing..... lol
    Jason.
