Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Starting trouble
    Jun 2008
    Melbourne Aspendale
    Starting trouble
    Hi all.
    Im having trouble starting my GF's 1980 GLD. IT broke down while she was driving it and she had it towed home. The RACV said it might be the starter motor so i swapped that out for a known working one. and that didnt fix the problem. When i turn it over it clicks but does not turn over. Apparently he checked the battery and it was holding 12V. Just wanted to know if there are any other leads as what it might be.
    Thanks in advance.
    Mark
    1980 GLD
    1979 300D Mercedes
    1980 300TD Mercedes
    1956 Desoto Panel Van... Maybe to comeback to life as a diesel???
    Canberra
    Does the starter incorporate the solenoid as well ? If it is separate then the solenoid could be RS.
    It might be worth checking the voltage at the starter motor and solenoid (rather than at the battery). If there is a problem with power and/or earth leads and/or connections the voltage might seem OK at the battery but be too low at the starter.
    Another possiblity is a problem with the teeth (or meshing/throw) on the flywheel.
    If you have any doubts about the battery at all iIt is worth trying with a known good one (even if it doesn't actually fit properly).
    Adelaide hills, SA
    Turn the headlights on while you're starting if they go off check the cables from the battery the thick ones if they're not getting too hot while cranking.
    My bet is that it is a battery, but check the cables first make sure you've got a good connection and no corrosion around battery terminals.
    Jan 2008
    Sunshine Coast
    I second Gregoz's solenoid idea, I've had the clicking, dodgey solenoid problem on my first car, you had to hit the solenoid each time with the steering lock before starting it!
    Aug 2007
    Check your earth cable mate, get an old set of jump leads and connect to the neg of the batt and the engine block then try it.
    cheers
    Jmac
    Alba European
    Oct 2005
    SE Queensland Hinterland
    What Jmac said. The earth lead from the battery goes down the right hand side of the engine bay, as you are looking from the front, and is bolted to the body, then the same lead runs over an engine mounting (from memory) and is bolted onto the engine. Both these places are dirt and rust prone, so a good clean-up well worht the trouble. If you think it is sus, replace it with a new one from your local auto parts (cheaper than OE) - and you can get a larger csa cable. On my GLD the earth lead gets really hot - but the car starts OK, it's on my to do list. When it was not starting very well I doubled up the cable as Kmac suggests and it improved heaps. Good Luck
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Jun 2008
    Melbourne Aspendale
    Ok Thanks for all the suggestions here is what i have done with no sucess
    1. replaced the starter. The selniod is incorporated with it so it was changed ovr with the original.
    2. Full charged the battery.
    3. Changed the postive cable to the starter with a new thicker one. I wanted to change the negitive one but unsure of how important it is to have it connnected to the chassis as well as the engine. i could not see any that doubled up like the orignial on the golf.
    4. Cleaned up all the connnections so that they were shiny and bright.
    5. hooked up a jumper cable from the negitive to the engine whilst trying to start.
    When i got my GF to turn it over both cables got extremely hot with a little bit of burning plastic smell. Is there something that i have missed. When it is bright again tomorrow i will hook up the merc battery to try to kick it over....
    Thanks again for all the suggestions.
    Looks like my girlfriend will have to push bike it to school again.
    1980 GLD
    1979 300D Mercedes
    1980 300TD Mercedes
    Adelaide hills, SA
    Can you turn the engine over with the socket on the crankshaft pulley?
    If yes, I would be replacing the battery.
    Canberra
    Quote Originally Posted by JustMark View Post
    OK, I'm going to go back and ask the question we should have asked at the start.
    What exactly were the original symptoms when it first "broke down while she was driving it" ?
    If the engine overheated drastically or was running without oil or made a horrible noise it might have seized or jammed internally. If a cambelt broke and the valves hit the pistons there will be a similar result. In any of these scenarios, no amount of fiddling with starter motors and/or batteries and leads will rescusitate her poor beastie.
    As Transporter is hinting, if the engine won't turn over then that is where the problem lies (hint, putting a manual in top gear and rocking it back and forth may turn the engine over enough to see if it is stuck or not).
    The fact that the cables to the starter got very hot suggests to me that the battery is probably capable of delivering enough current, but either the engine won't turn over or the starter is jammed/cactus.
    Please keep us informed of developments.
    Gosford Central Coast NSW
    ohhh boy.
    mate, if the car stopped while running, then i would say its one of the following
    > electrical problem - namely something wrong with current track 15 - thats ignition on. this poweres the stop solenoid. if no power there, nomatter how much you crank, tow or jump the car, it wont start. no fuel. there must be 12V to the stop solenoid on the injector pump when ignition is on - has this wire broken?
    >how fast does it crank over? it should be really fast now that you've re-vamped the starter and cables. if its slow, you might have a timing problem.
    >pull the valve cover off and the timing belt cover. take out the timing plug from the bellhousing and line up the crank at TDC. check that the slot in the end of the camshaft is lined up exactly with the top deck of the head. check that the small hole in the injector pump front sproket is lined up with the hole in hte pump mounting bracket. if any of these are out, your timing is out.
    >check the oil. make sure there is only oil in it, and not water etc.
    >check that the fuel is getting through - you may have a blocket filter (will stop you while driving) OR you have an air leak that the pump cannot overcome. check all the fuel lines between the metal lines and the pump - both supply and return. if htey are suspect, replace with new and use new hoseclamps.
    i would NEVER trust what some roadside assist mechanic has to say about an old vw diesel - they NEVER know what the hell they're looking at. my sisters GLD wouldnt start one day, and i had the nrma guy passed to me on hte phone (my sis called me bacuse i know about the car) and he had no idea what so ever. hopeless git. all it needed was a good fast crank (or a tow start) because it seemed not to be glowing properly. i could tell that from what my sister described to me over the phone - but HE had them chasing fuel filters and starter motors too. next time my sis came up, we changed the glo plugs and now it starts perfectly, every time.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
