Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Starting issue. 2012 Tiguan
    Dec 2008
    Sydney/Canberra
    Brake lights don't get full battery voltage anyway, as they're illuminated via a PWM signal. i.e. the BCM only sends enough voltage to sufficiently illuminate them.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2014
    Central Vic
    Quote Originally Posted by Umai Naa!! View Post
    Interesting, thanks
    I'm so protective of the battery in the latest vehicles I don't even have interior lights in the 'armed' mode.
    My 308's radio won't go long without the engine running either.
    It seems to me the under bonnet space needs to prioritise a larger battery (higher capacity) these days.......or go the expensive BMW route.
    Mar 2017
    Tasmania
    Starter motor won't engage until the control unit tells it that the glow plugs have reached temp. Takes longer the colder the vehicle is.
    Aug 2012
    Perth WA
    Quote Originally Posted by doc_777 View Post
    I have re read my post and can see the confusion.
    If I leave the ignition on without starting the car for 5-10 seconds to allow the glow plugs to reach working temps, the the engine starts first time without fuss. If try to start the car immediately, then there is a pause in the starting sequence.
    My bad. I hope that this clear as mud.
    Pacific Paradise QLD
    Quote Originally Posted by Amalgam View Post
    You have answered your own question about what to do then Havent you.
    Always has been wait for the glowplug light to go out before hitting the button. Even on my 1963 Farmall tractor.
    Adelaide hills, SA
    The older diesels were more dependent on the glow plugs than a new CR diesels, and can start very fast in summer. But when the temperature gets closer to 0 deg. C, it's better to wait for the glow plugs light to go off.
    Any diesel from 1963 would struggle to start without the glow plugs working 100% at any temperature and would not start at sub zero without them.
