alright guys, heres a little experiment i have done to demonstrate to you just fine the line is between smoke and power, and why if you want to DPF delete your new golf, then it shouldn't be a problem for your concience...
until now, i've been running stock boost on the mk3 - 12psi under constant load conditions.
i have also had fuelling set to produce what you might call a plume of black magic, a good amount to get rid of the annoying p-plater behind you, that sort of thing.
i just fabbed up my $4.00 boost controller from bunnings. 2 drip irrigation screw adjustable valves, tee'd into the waste-gate actuator line to bleed off air. works very nicely!
without touching fuelling (been the same for 3 months), i first increased full load constant boost to 13psi, then 14psi, and now sitting at 14.5psi.
at 13psi, i noticed i slight reduction in smoke at full load, but it was not hugely significant. up to 14psi, a further reduction in smoke was obvious, as well as power being slightly better. now at 14.5psi, i notice very little smoke at full load.
the car definately pulls harder now, though the real increase may be small, it is noticable (even the missus noticed the car was faster).
just goes to show however how a small increase in boost pressure can bring the smoke levels right down. i tried to "smoke" some guy in a lexus 4wd last night who was sitting less than a carlength behind me, at 110km/h in the rain, and i couldnt! i jsut pulled away instead! now i have power instead of smoke..... ohhh the shame!
