Results 11 to 20 of 26
Thread: running out of fuel
    Pacific Paradise QLD
    Quote Originally Posted by Ryeman View Post
    Is it the same as the handbook quoted capacity?
    Possibly, probably. Fill it when the light comes on and you wont have to worry.
    All this worrying about minor details. Fill it up, go somewhere, fill it up again.
    If I had to worry about fuel consumption I would ride a bike.
    Feb 2014
    Central Vic
    So you don't care what brand you use?
    The thread is 'running out of fuel' not economy, or have I missed something?
    It does happen.
    It does happen.
    I usually use one brand and make sure I never get the level too low. Prefer to fill up earlier than later. However if needed I dont mind using another brand except Ethanol added ones. Your reply 8 refers to economy or did i miss something.
    Have just done a 990km trip in the Passat and neither ran out or brought the low fuel light on.
    It does happen usually by unobservant drivers who dont watch the instruments or ones run it too close to the wind.
    Feb 2014
    Central Vic
    It's not a problem if live in a large city but sometimes in the country a brand can be difficult to find in more remote areas, particularly the Vic High Country touring.
    Erskineville, NSW
    In my fuel guzzling TSI the light comes on at 1/8th of a tank. This is usually about 100km DTE after having already done 600km.
    I think if I was tooling about a remote area I'd ensure that I topped up with fuel when I got to just below 1/2 (about 400km running). On AU roads, 400km is about 5 hours driving so it's probably sensible to stop & have a break.
    If you owned a Holden Craptiva V6 or similar you'd have no choice but to fill up after 400km as you'd be on empty anyway. Anything above that is a bonus.
    The only other suggestion I can make is fill a 20L jerrycan with fuel and see how far you can get on a tank.
    Oct 2010
    Melbourne, VIC
    That's what the OP was thinking of doing and why he asked about consequences of running a diesel empty.
    Resident grumpy old fart
    Erskineville, NSW
    Quote Originally Posted by kaanage View Post
    Maybe he should "Just do it" rather than having circular conversations...
    May 2012
    I simply want the basic ? as to what is the 'useable' quantity?
    And
    Sometimes I just want to get to my preferred brand.
    Pretty close - I once put 55.5L in my 55 litre tank, filled it right to the brim tho. The car hadn't stopped yet when I filled it, so there was some more in there still. (It happened because I believed the km to empty on the dash display ... not recommended! It said 200km when I left home, 100km later it is reading 0km remaining. Should have been sceptical because the l/100km is also wildly optimistic.)
    Feb 2014
    Central Vic
    ".....wildly optimistic"
    I'll say.....reality strikes home as you say in the last 100km particularly in mine with a tuning box which indicates better economy at 100 than 80 and makes the maxidot figures a joke.
    Erskineville, NSW
    That's really interesting that you don't trust the MFD. Mine is within 0.1L/100km of the calculated figure.
    You realise that you can tweak the L/100 average with VCDS?
