"Running In oil" and normal oil.
there are really only 2 types of oil in the world -
oils with friction modifiers.
oils without friction modifiers.
some car manufacturers specify a specific oil to use - it may have friction modifiers, suited to the engine components that they used - e.g. specific alloy combinations etc.
basically, there is only a couple of rules that you need to go by to get the best out of your car.
running in oil, is oil without friction modifiers. this may be sold specifically, from a dealer, otherwise it is - all penrite oils, all pennzoil oils, and a couple of other select brands.
generally all other oils have modifiers.
if you use an oil without friction modifiers, with a vehicle like a VW, merc, bmw, volvo, etc - european baes manufacturers, you will have a long and happy motoring life with your engine.
oils with modifiers will only make a difference to the service interval you should use, and only if the modifiers are suited to the engine components.
all of this is NOT to say that all engine oils are created equal - they are clearly NOT.
the main thing to take from this is:
1. change your oil more regularly than necessary
2. use a good quality oil
3. don't change oil brands too often - try to stick to one that works well.
4. DO IT YOURSELF so you know what goes in and what comes out!
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
