They clog up nicely on standard cars over here, throwing it into limp mode (or worse)
Severely limits the tuning on them too. It won't be long until someone makes a DPF delete kit though
From the new VW mag:
This shows why the bigger turbo on the GT can not spin to its full potential. Look at that nasty tin can hanging off the back of the turbo in the first pic
Cheers,
Jamie
I quite like the concept of the DPT - for a small price to pay in performance you get a very clean car. I'd much rather a DPT TDI than a Prius for example![]()
I too like the idea of a "clean" performance car, but the catch 22 is I believe the DPF uses an injected catalyst to burn off the carbon, and if so, the catalyst I read about is a major carcinogen. "Apparently" there is a small tank of this nasty stuff, that needs toping up a few times in the car's lifetime.
IF that's the case with VW ( still looking into this ) it's ultra fine particles and soot, or carcinogens.
My inital thinking was a DPF off a bigger diesel, such as a transporter......
But if the carcinogen thing is true, I'll go with a deletion in a heartbeat! With the right state of tune, I'm sure the amount of soot could be FAR more controlled than most other diesels out there.
Cogdoc, you might want to look into the catalyst info a bit more. If you are talking about the urea injection system that some manufacturers are using to pass the stricter US pollution regs, then I think you'll find this isn't being used by VW on their 2.0 and 2.5 diesels (possibly is on their bigger engines). I have read some stuff about BMW and MB using it. Try looking on the US TDI sites, I'm sure there is volumes of discussion about it there. Or if you really want to exercise your brain, have a look here http://ect.jmcatalysts.com/technologies-diesel.htm
I thought urea was fairly harmless stuff (I certainly hope so, as something closely related comes out of my pen!s every time i take a leak)
If you want to get all hot and bothered about exhaust carcinogens I think you'll find that the VW DPF system creates significantly less than the non-DPF VW diesel engines.
Tuning can certainly reduce the amount of soot produced, but it does this by leaning out the mixture, which unfortunately reduces the amount of power produced, particularly at lower revs (before the turbo is pumping big volumes of air into the intake) - the old "no free lunch" issue.
the dpf doesnt use a catalyst and is a non-servicable item...
talking of clean cars.... the dpf catches soot particles...
the soot from diesel engines is not bad stuff, its basically dirt. if falls on to the ground, then washes away or gets picked up and sticks to your car when its wet. it doesnt contribute anything to smog as much as many other things such as sulphur. diesel soot particles are so big that they litterally fall out of the air...
the DPF is a sales technique. diesel soot is an easy target to pick on for emissions, because its visible. doesnt mean its bad.
i'm more worried about petrol engine exhaust myself....
has anyone noticed lately that behind each and every toyota kluger there is a foul smelling cloud of sulphur dioxide? next time you smell something aweful in traffic, i'll bet there is a toyota kluger infront of you.
all petrol 4wd's should be BANNED! NO, BLOWN UP!!!
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
