Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Redlining a diesel
    Oct 2010
    Melbourne, VIC
    Redlining a diesel
    Will this hurt a diesel since it has a heavier crankshaft, rods and pistons than a petrol engine of the same size? Or will it hurt the unit injector pumps in a PD engine?
    I assume the valve gear won't care since the redline is so low.
    I sometimes redline it in 1st since the gap between 1st and 2nd is so large.
    Jul 2005
    Newcastle, NSW
    It will protect itself from damage with the limiter.
    I don't think your the only one that redlines the TDI. I know I do.
    Feb 2010
    Not much point in redlining a Diesel since the engine is most effective at about 80% of max rpm. I remember my Astra was an absolute animal at 4,100 rpm and it had the cut-out set at 5,100 rpm.
    Jun 2007
    Eastern Suburbs Melbourne
    as long as you don't exceed the red line, i'm reckon it'll be fine. I'm sure VW tested it above and beyond.
    I give mine a good rev everynow and then, power drops off about 850-500 rpm before red, so it doesn't often see it though.
    i like volkswagens
    Apr 2010
    Rowville,Vic
    Give it heaps (within reason) IMO, clears the turbo vanes and car runs better as well
    MY19 Polo GTi 2.0 DSG
    Previous VW cars:MY16 Polo GTI manual, 2007 Jetta 2.0 TDi manual, 2001 VW Bora V6 4-Motion - flooded away
    Nov 2007
    Like in a Petrol engine you're not really going to blow anything up - just shorten the life of the engine eventually. I'd recommend you change a little before redline though. If you look at dyno graphs you'll see that most diesels drop off heavily in power and torque near redline so there's no use going higher than 4000rpm in most cases and even with the drop in revs when you change gear you'll still be in the meat zone with an early shift because of the relatively flat torque curve of the diesels. I read an article somewhere on the net where they did 0-100 and 400m testing on shift patterns in the diesels and the one's shifting earlier before redline were dramatically faster.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Feb 2010
    Go a few kays at 4,000 rpm in third every now and then to get the engine rid of soot. i think the "procedure" is called "the Italian clean"
    Oct 2010
    Melbourne, VIC
    Actually, the redlining is occuring sometimes when I downshift form 2nd to 1st a bit too early.
    I never go near it on acceleration (never really get near to 90% of the red line, usually potter around 30%)
    Quote Originally Posted by kaanage View Post
    Yes that can harm the engine if you're exceeding the redline.
    A rev limiter won't stop the engine from spinning over the redline on down changes.
    Pistons will hit valves eventually depending on what revs you're seeing. Did this once on my race bike at the track, not fun...
    MKV Golf 2.0 TDI DSG Sportline. Just nice.
    Oct 2010
    Quote Originally Posted by stickshift3000 View Post
    Except the DSG wont shift down if it will result in too many revs. Maybe he has a manual though.
    Golf GT Sport TDI
