the starter eath cable stuff is all good, but if its cranking over ok then make sure its not air thats the problem...
make absolutely positively sure that you dont have any air leaks letting your pump drain dry after the engines been off for a while. when i say this, i mean tighten all of your fuel line hose clamps so that you KNOW that air wont get in, make absolutely sure that your return lines are all without holes or cracks (they tend to crack up where they go over the nipple on the side of the injectors) and that all the banjo fittings on your pump are secure.
a lot of people go on about having air in the system making your diesel run badly, but the golf pump is not so susceptible because of its "self priming" ability - it tends to bleed out the air quite well - when the engine is running. SOME pumps will self prime well, not all, and so air before startup is a problem. depending on where the air can get in and how you parked your car (slope etc) you might not have any problems at all with an air leak or you might have trouble starting all the time. its hit and miss, annoying and i'm speaking from experience - mine did this kind of thing after every fuel system adjustment at one time in the past...
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
