Wouldn't we all love a new Tdi??? In lieu of that, a quick ring job would be cheaper. Yes, it can be done with the engine in the car and it's cheap enough if you source the parts in the US. But first... Check everything else, You say your glow plugs are OK. Are you sure? What about the relay? Eliminate all else before spending time and money on a re-build. If you suspect low compression do yourself and your bank account a favour and have a compression test done. Compression has to be really low before it affects starting. Even with considerable blow by to the point of runaway, it should still start. I would strongly suspect glow plugs to be the culprit. Get back to me if you want a step-by-step checklist.
