Its not all that neccesary on the Mk5s.
Cheers, Andrew![]()
Is anyone running an automatic turbo timing on their TDI Golf/Jetta? Or is anyone considering doing this?
Cheers, Andrew![]()
I've driven a toyota bus with one, very strange experience i reckon. That aside, ive been driving Turbo Diesels for most of my life and just use the simple rule that i always drive it slow the last 4 or 5 k's home if i have been pushing it on a bit to give the turbo a chance to cool down. If i have been pushing it away from home and have to stop i let the engine run a bit when i pull over.
currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
If you could ever get your turbo so hot!!!!!!! You would have to drive your car all day flat out to cause any problem to require such a devise. Trucks & heavily loaded vehicles may need one. If it worries you just let your engine idle for about a minute before turning it off. READ your owners manual...
regardless of what the owners manual states, its not difficult to get your turbocharger hot - have you seen how small a VNT turbine is? tiny! they do crazy rpm.
not saying the owners manual is wrong - but if you modify your diesel to make it faster, theres no reason you couldnt get the turbo very hot indeed..
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I think that in general turbo timers are unneccesary and have only briefly considered and then rejected it as an option for the following reasons;
If I am driving hard, I will warm down the engine before I stop
I don't want to mess with MKV's complex electrics
They are illegal in most places
I am not a ricer and have nothing to prove (jokes)
But you can install one, just unsure of the need to.
