Goodo.. Things are moving. Don't use any gasket sealant on the head gasket, will youOriginally Posted by posscakes
If you have access to a lathe you can make a locking pin. It's really just like a bolt with the shaft turned down to a smaller diameter. The "fat" part fits in the ip sprocket and the "thin" part into the block. I'll search mine out and measure the diameters for you. It's home made but it does the job.are there any specific tools required for the job ie to lock the ip
I made a plate out of a piece of mild steel. I ground it down until it was a tight fit into the slot in the end of the camshaft and I gently tap it in. Works a treat.and cam shaft,
No secrets there. Just like a petrol belt.tension the timing belt
And you will! They scare a lot of people off diesels.etc ive read a few conflicting articles...
A couple of hints.
* line up the TDC mark on the flywheel exactly. No room for error.
* Turn the engine in the direction of rotation when you do this to keep the belt tight on the drive side and then lock the ip and the camshaft.
* Clean the face of the head and the block thoroughly. Don't get the head skimmed. You may find small cracks between the valve seats. That's OK as long as they are small.
* Check the head for warping with a straight edge and feelers once its face is clean. If it is warped it can be straightened professionally (but people who can do it are hard to find).
* Before you bolt the head down clean out the bolt holes in the block so there is absolutely no oil, dirt or water in them. Blow them out with air and then use a rag on a screwdriver to get them thoroughly dry and clean.
Good luck!
