Page 7 of 14 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 140
Thread: Provent / catchcan fitment kits.
  1. #61
    Jul 2010
    Elanora Heights, Sydney
    Without trying to spark another flare up, did these brackets ever get done? I can see a few bits on the website. I wanted some way to mount my provent into my wifes passat.
    Thanks!
  2. #62
    Jan 2008
    Sunshine Coast
    Nope. The stock Provent bracket is a nightmare to make a bracket for at a inexpensive cost to suit a myriad of cars...I have put it on the shelf for now, afraid you'll have to get creative!
  3. #63
    Jul 2010
    Quote Originally Posted by Greg Roles View Post
    Theres nothing a handful of cable ties cant fix!
  4. #64
    Oct 2010
    Melbourne, VIC
    I'm looking at the smaller Provent 150 for the Polo's, still trying to get one into the country vian Mann and Hummel for testing. You guys have limited engine bay room!!
    Any progress on this front?
    Resident grumpy old fart
  5. #65
    Aug 2011
    melb, VIC
    Hey Greg, got any left for a mk6 tdi ?
    mk6 TDi - DSG -VIEZU tuned- Carbonio . Whiteline RSB/Neuspeed FSB . Golf R interior . Defi boost . Twin 4" Magnaflow tips . GTI shocks & springs
  6. #66
    Jan 2008
    Sunshine Coast
    Guys the Provent idea is still something I want to do, but it's a mission, and I need funds to put into R&D. Viezu will give me that, so for now, that is my emphasis. You can get Provents delivered from Western Filter and the like on e-bay for $170, which is a bloody good price, I have to buy quantity to make it worthwhile at that sort of deal, so again, I'm putting this in the mid to longer term basket. Grab them off e-bay for now.
    The Provent 150 cost the same as the 200, flowed far less, was considerably poorer in it's design in my opinion, so if you have a diesel, you need to make the 200 fit - somewhere. You are right that zip ties are fine, the can just needs to be held to stop it flapping around, doesn't need structural support really.
  7. #67
    Oct 2010
    Melbourne, VIC
    As always, your advice is invaluable - I just wish the Provent 150 was in the same ball park as the 200 since there is so little room under my bonnet
    BTW Do you see any problem if I downloaded and used the PWGPro 3.93 software from the Alientech site with my V-Switch? The Viezu branded version of PWGPro that I have is only 3.80.
    Also, I will be dynoing my 3 Viezu maps vs the stock one for my 1.9 PD soon - would you like me to send you copies for reference?
  8. #68
    Nov 2005
    Sydney NSW
    Anything will fit!!!
    here's mine mounted to the back of my Battery Tray:
    Also the filter does not have to be replaced every 10k km but probably 50k km. so putting it where I have, only means uncliping a few sensors above it. I think it is harder to get my oil filter out the way it is stuffed in there!
    Last edited by Gigitt; 23-02-2013 at 07:06 PM. Reason: Updated Picture hosting path
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
  9. #69
    Jul 2011
    NEWCASTLE NSW
    I took mine off today,
    simply I'm over it.
    and its barely connected any oil during 15,000kms( less than 100ml)
    going to put it in the sale section.
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
  10. #70
    Aug 2011
    Lake Macquarie
    Quote Originally Posted by lowtdi View Post
    simply I'm over it.
    I'll buy it.
