By then it's too late to bother mate. Oil ash buildup is what kills the DPF and the PCV vapour / EGR soot builds up in the manifold, ports and bakes onto intake valves. Using a inlet "sea foam" type flush, that is one specific to diesels, is one option, but in my mind just ends up in your DPF. No way a genuine Provent 200 in the stock PCV system could be seen as a warranty killer, for the manufacturer Mann and Hummell build a vast majority of the plastic air boxes, inlet, manifold and filtration systems on euro cars, and apart from sucking in dirty air via an open drain tap, I can't think of a way it could cause harm. It is CE marked etc etc, just watch out for the China fakes, they DO cause problems.
Still your call, given what I'm about to do to the Yetis DPF system, I think my local dealer won't be too worried about the Provents!
