Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 140
Thread: Provent / catchcan fitment kits.
  1. #121
    Jan 2008
    Sunshine Coast
    Yep, but return to sump is not ideal in a diesel as you are already hammering your oil with soot and diesel blow by, so the Provent drain is better discarded. I ran a return to dump in the Golf, but did change the oil twice as much. This time I'm draining it off.
  2. #122
    Jan 2008
    Sunshine Coast
    I still need to put one on the Caddy.. Hoping the water/methanol kit helps to clean the inlet, though.
    It will indeed keep it spotless, but that PCV oil still ends up in a DPF if fitted.
  3. #123
    Feb 2014
    Central Vic
    Greg, how do you drain it off from low down on the firewall with all the plumbing in place on a/my Yeti?
  4. #124
    Jun 2006
    Orange NSW
    Quote Originally Posted by Greg Roles View Post
    So.. Are you selling water/meth kits?
    I don't currently sell one for a diesel and I like to support local business.. It is after all in our own best interests. Haha.
  5. #125
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by Ryeman View Post
    Tube hangs out transmission tunnel and I fixed it below the passenger floor pan.
    Mate Snow is distributed by Rocket Industries, and Devils Own had like 5% margin, so nope. I would recommend Snow for the digital controller, and Devils for odd parts, as Snow have crap aftermarket service. Snow do have an awesome Max mileage twin nozzle diesel kit, but you really only need a stage one boost referenced one as EGT reference is only really for towing up prolonged hills. I found much better performance when referencing boost as opposed to EGTs.
  6. #126
    Jun 2006
    Orange NSW
    Copy that. I'll talk to my mate Graeme... or more likely, one of his sales guys. Haha.
  7. #127
    Feb 2014
    Central Vic
    Greg, just clarify - the catch can collects the sum gasses but how does the oil contaminate the EGR?.
    I thought the exhaust gas was free of blowby oil which was a PCV issue.
    In other words does the Provent stop oil somehow contaminating the EGR?. ....Does the PCV allow/direct oil vapour to the EGR..
  8. #128
    Gosford Central Coast NSW
    The crankcase gasses contain an oil mist. Usually crank case gasses are returned into the inlet pre-turbo.
    The EGR gasses are incorporated to the inlet air after the EGR valve, post turbo.
    When the EGR is recirculating, the soot laden exhaust gas is mixed with oil laden crank case gasses and combine to deposit black carbon rich goo on the walls of the inlet after the EGR valve.
    A provent or other catch can helps reduce the content of oil mist in the crank case gasses which in turn reduces the propensity of the EGR + Vent gasses to form goop.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  9. #129
    Feb 2014
    Central Vic
    When the EGR is recirculating, ............
    Do you mean for a second time?.
    Under what circumstances does it 'recirculate'?
  10. #130
    No, I mean when it is operating. Valve open. It's nature is recirculating.... It recirculates exhaust gas through the engine.
    Sent from my Nexus 5 using Tapatalk
    '99 A4 Quattro 1.8T
