Page 12 of 17 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 170
Thread: Poyta's GT
  1. #111
    Nov 2007
    Quote Originally Posted by Gigitt View Post
    but you forgot to swap the reverse and fog over as for RHD cars
    There's no easy way to swap them over. I would have to break apart the light case which is glued together , pray it doesn't snap then changed them over and re-glue it. Hardly worth the effort, I mean who cares if the Reverse light is on the left side or right side as long as it lights up when you put it in reverse right?
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  2. #112
    Apr 2012
    Victoria, S/E
    Poyta's GT
    100% agree poyta, I'm thinking of going led tails at some stage and I don't think ill be changing the fog and reverse light... I know it's a legal thing but unless I get pulled up I wouldn't bother changing them...
    Hennessy Auto Styling MK5 TDI [SIZE=3]|| United Grey || Sunroof & Leather || 18x8.5 +45 Rotiform BLQ and 17x8 17x9 +39 Stern Reverse Face II || K Sport Deluxe Air Suspension || After Market OEM Style Body Kit and Accessories!
    Hennessy Auto Styling - Bumpers, Spoilers, Carbon, Lips and more.
  3. #113
    Nov 2007
    Quote Originally Posted by lhennessy View Post
    I actually don't think there is any Australian legislation that states which side the reverse light has to be on, all I know is that you need as minimum one reflector and one reverse light, three brake lights and two indicators. In any case which side the reverse is on is the last things that a cop would be concerned about- biggest concern is the dark tint on the lens which is bloody obvious and the complete lack of ADR compliance. Sorry but unless they have an ADR stamp on them they are not legal and a police officer has every right to defect you for them and ask for them to be returned to factory spec. I have yet to see any aftermarket tail-lights that have the ADR seal of approval. You take a risk with these - hence why I'm keeping my originals just in case.
    If you're thinking about leaving the wiring as is and therefore you get a FOG light switching on when you select reverse then I'd say thats a NO NO. It will be even more obvious to police and probably a little dangerous too - not that the pissy little reverse light does anything to light up the view but it at least warns others of your intention.
    At minimum you should at least flip the wiring so you get the correct light going on but as to which side its on, who cares.
  4. #114
    Nov 2005
    Sydney NSW
    pretty sure there would be an ADR on it... pretty sure policing it is non existant with all the BMW and Excels still driving with them on!
    The reason it is there is so in heavy fog the cars behind you know which side to pass on especially if you have stopped in traffic... other wise you could be rear ended. In heavy fog that light can save you ass butm how many Aussies would know this about a rear fog light.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
  5. #115
    Nov 2007
    Starting toying with the idea of Vinyl wrapping.
    Thought perhaps I may start with the most difficult part first to see if I could get away with it and see any potential problems so decided to tackle the side mirror covers.
    Decided to go with Carbon Fibre and bought some of the 3M DiNoc vinyl - this is a heavily textured vinyl where you can feel the actual texture of the carbon weave and even the weave itself has an angled cut surface design to refract light just like real Carbon Fibre.
    Word of warning to anyone want to attempt this -the mirror caps are a very intricate shape and its a major pain in the glutts to do it right. You will definitely need to get some 94 primer to paint some of the complex curved surfaces of the caps otherwise the vinyl will not bond and will come unstuck and you need a second pair of hands to help with the actual vinyl application as there's a lot of heat gun work and stretching required. I tried it on my own and stuffed it. Also I'd say its best to avoid using the DiNoc series and go for the 3m Scotchprint 1080 series. It more expensive but its a lot thinner and easier to work with. I've also been advised its more designed for outdoor use so more suitable for car applications. Downside is that the 1080 doesn't seem to have as nice a texture as DiNoc. Its still textured but generally is a bit flatter and doesn't refract the light as effectively. Its also a bit darker in colour than the DiNoc.
    Here are the caps after I finished.
    And here are the caps fitted to the car.
    Keep in mind that like real Carbon Fibre the sheen dramatically changes depending on the outside light, so in a bright sunny day or under a garage light ( like in the photo above ) they have a real metallic shine to them while if its overcast they look quite dull. I have attempted to take a few photos in various conditions to show you what it looks like.
  6. #116
    Jan 2013
    Kiama, NSW
    Poyta your work is one of the factors on why I kept my Gt Tdi... That and the fact I can give it an absolute flogging and use f*ck all fuel...
  7. #117
    Aug 2011
    melb, VIC
    They came out really nice ! You can put armour all on them, helps with the finish
    mk6 TDi - DSG -VIEZU tuned- Carbonio . Whiteline RSB/Neuspeed FSB . Golf R interior . Defi boost . Twin 4" Magnaflow tips . GTI shocks & springs
  8. #118
    Jul 2011
    Poyta's GT
    You have definately nailed it there Poyta, once again an inspirational tdi for all of us to follow in its path! Keep up the great work
    08 VW MKV Golf TDI - reflex silver | pioneer nav unit | 18" black Apec racing rims | DSG | custom TurboBack exhaust | reset springs | gti steering wheel | R-Line tail lights | angel eye/projector headlamps | gti front | R32 rear | red engine cover | opticoat |
  9. #119
    May 2011
    Poyta's GT
    Looks the bomb man. Your attention to detail is amazeballs.
    2007 Golf MKV 2.0 TDI DSG
    | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
  10. #120
    Bowral, NSW
    Quote Originally Posted by poyta View Post
    I see your MAF grille has the four strange indentations as mine.
    I can't, for the life of me, find a way to remove it!
    Would love some more sexy sexy induction noise with the Carbonio.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
