Yep, the Hawk HPS pads I put on mine definitely don't have the initial bite of the OEM pads. Like you said just takes a bit of getting used to.
Odd you had the GTI rear discs, mine definitely aren't. What was the option code on your receipt?
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
Golf GT Sport TDI
Wow that looks awesome, well done!
The bigger rotor will resist fade as much as anything anything - bigger heat sink!
He's talking about selling the gt/GTI brakes not the R brake![]()
Hennessy Auto Styling MK5 TDI [SIZE=3]|| United Grey || Sunroof & Leather || 18x8.5 +45 Rotiform BLQ and 17x8 17x9 +39 Stern Reverse Face II || K Sport Deluxe Air Suspension || After Market OEM Style Body Kit and Accessories!
Hennessy Auto Styling - Bumpers, Spoilers, Carbon, Lips and more.
I know, I'm saying that RS's don't have much clearance inside the wheel so me buying and trying to get on R brakes is not even worth bothering
Ohm my bad sorry from the quote I thought you were talking about his previous setup, I think they di fit under them because there was a set of purple bbs (not RS tho) in purple wil r32 brakesand plants of r32s with bbs so they should?
From what i understand, the only difference (ignoring the carriers) between the stock GTI and TDI front brakes is an increased rotor size (288mm Vs. 312mm). Assuming you have no issues with your brakes at the moment, you shouldn't have any issue with horizontal clearance with GTI fronts. Vertical clearance from an increased rotor size is another matter though...
Having said that, I dont think there would be a massive difference in braking ability by simply changing rotor size alone. I guess if your brakes are rooted there's no harm in upgrading though.
If you asked around at BriSkoda, I think you'll find R brakes fit with stock vRS 18" rims.
They even fit under 17" Zeniths without spacers
345mm Cupra/r32/s3 Front Brake Upgrade - Skoda Octavia II (2004 - 2013) - BRISKODA.net - The Skoda Forum and Community
Keep in mind that the 345mm R brakes are a 7kg premium over the 312mm GTI units (per assembly) 7kg extra unsprung weight is a lot!
