Poyta's GT-img_0898_zpsf1d44ce1-jpg
Coil-overs are in!!!!
Unfortunately I cannot take full advantage of them and drop the car by much. Can only manage to drop the car an additional 15mm from what I had before with my lowered springs ( so total from stock about 50mm ) before I get to the point where the car is un-driveable due to wheel clearance in the front guard - initially I dropped it about 20mm from what I had before and turning out of the driveway the tyres scrubbed badly on the wheel arch - took a nice bit of paint off and slightly dented the guard too so I had to raise it another 5mm. So currently it looks like this -
Poyta's GT-img_0905_zps6d67c246-jpg
As it is now I have no issues with any bumps as long as my wheels are straight and can take the occasional small bump on turns - still not ideal as I'll be in real trouble if I hit a severe dip while turning so I'm going to look into getting the guards rolled and flared , may as well since I need to get them repaired and painted anyhow.
For anyone interested my wheels are 18"x7.5" with an offset of 45 and I'm running 225/40/R18 tyres. Will look at getting new wheels in the future with a higher offset and this combined with the pumped guards should allow me to drop the car more.
With regards to the ride I can report that its fantastic! Even at this lower height Its certainly much softer and plush then when I had just the lowered springs but having said that its not quite as nice as a stock - I would say its kind of in between factory standard and lowered springs.
