Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 170
Thread: Poyta's GT
  1. #81
    Nov 2007
    Quote Originally Posted by getjet View Post
    What are you going to do with your old front brakes?
    I suppose I'm going to sell them so if anyone is interested let me know.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
  2. #82
    Oct 2010
    Yep, the Hawk HPS pads I put on mine definitely don't have the initial bite of the OEM pads. Like you said just takes a bit of getting used to.
    Odd you had the GTI rear discs, mine definitely aren't. What was the option code on your receipt?
    Golf GT Sport TDI
  3. #83
    Jan 2008
    Sunshine Coast
    Wow that looks awesome, well done!
    The bigger rotor will resist fade as much as anything anything - bigger heat sink!
  4. #84
    Nov 2007
    Quote Originally Posted by jazd View Post
    Rear discs were listed as 1K0 615 601AD
    Pads were 1K0 698 451K/C
  5. #85
    Mar 2012
    Quote Originally Posted by poyta View Post
    Could be interested, highly doubt I would get R brakes inside the RS's. Doubt they would have the clearance
  6. #86
    Apr 2012
    Victoria, S/E
    Poyta's GT
    He's talking about selling the gt/GTI brakes not the R brake
    Hennessy Auto Styling MK5 TDI [SIZE=3]|| United Grey || Sunroof & Leather || 18x8.5 +45 Rotiform BLQ and 17x8 17x9 +39 Stern Reverse Face II || K Sport Deluxe Air Suspension || After Market OEM Style Body Kit and Accessories!
    Hennessy Auto Styling - Bumpers, Spoilers, Carbon, Lips and more.
  7. #87
    Mar 2012
    I know, I'm saying that RS's don't have much clearance inside the wheel so me buying and trying to get on R brakes is not even worth bothering
  8. #88
    Apr 2012
    Victoria, S/E
    Poyta's GT
    Ohm my bad sorry from the quote I thought you were talking about his previous setup, I think they di fit under them because there was a set of purple bbs (not RS tho) in purple wil r32 brakes and plants of r32s with bbs so they should?
  9. #89
    Dec 2009
    Melb. (SE), VIC
    Quote Originally Posted by mk5_tdi View Post
    From what i understand, the only difference (ignoring the carriers) between the stock GTI and TDI front brakes is an increased rotor size (288mm Vs. 312mm). Assuming you have no issues with your brakes at the moment, you shouldn't have any issue with horizontal clearance with GTI fronts. Vertical clearance from an increased rotor size is another matter though...
    Having said that, I dont think there would be a massive difference in braking ability by simply changing rotor size alone. I guess if your brakes are rooted there's no harm in upgrading though.
  10. #90
    Erskineville, NSW
    If you asked around at BriSkoda, I think you'll find R brakes fit with stock vRS 18" rims.
    They even fit under 17" Zeniths without spacers
    345mm Cupra/r32/s3 Front Brake Upgrade - Skoda Octavia II (2004 - 2013) - BRISKODA.net - The Skoda Forum and Community
    Keep in mind that the 345mm R brakes are a 7kg premium over the 312mm GTI units (per assembly) 7kg extra unsprung weight is a lot!
