Originally Posted by
Seano
You also need to bear in mind that these units are made of stainless steel. So they can't simply be welded into place in a normal mild steel exhaust system.
as above, just to clarify, you can, its no problem. different welding methods produce differing results, but in any case its A-OK.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
