Nice find. It's intresting there are a lot of these alternate options out there, I've discovered a few along the way, and it seems come DPF replacement time, once your car is out of warranty, there's a lot of cheaper options. You can wld stinless to mils steel, it's just that it's not ideal, and the weld's would be messy and rust. Still if it saves you a few thou over an OEM VW DPF, I could live with it.
And Ayden mate, you WANT an oversize DPF, as it's such a major restriction, I'd be trying to fit a 5" one from a small truck!! It's why I'm putting a 3" muff in a 2.75 / 2.5" system, as it's the point of restriction. Bigger is indeed better for flow ( up to a point ).
