Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: pod filter
  1. #51
    Logzy Guest
    Quote Originally Posted by cogdoc View Post
    Logz it's only dual cone INSIDE. The air enters around the sides and the inner cone directs the flow. The front is blanked off, and yeah a "airplane front" nose would be a clever idea. You're not as silly as your avatar pic suggests!
    When i first saw the pic it did look like it only took air from around the outer sides thats why i suggested the nose cone but your comment about ......knowing their stuff made me think it must also take air in from around the inside of the cone also.
    Now that its all clarified there's no doubt a nose cone would help with smoothness of flow and reduce turbulence.
    Must go and order me one of those air filters you have and get modding.
    Have you finished your install with the modshack housing yet.?
    Still no probs with no MAF screen.?
  2. #52
    Jul 2005
    Newcastle, NSW
    No problems with out MAF screen for me.
    Had dealer upgrade ECU software and have 3rd gear wheel spin in dry under everyday acceleration - ie. with kids in car on commute!
  3. #53
    Logzy Guest
    Quote Originally Posted by mikinoz View Post
    What was the ECU upgrade for.?
    Are you manual or DSG.?
  4. #54
    Jan 2008
    Melbun
    whered you order yours from greg? im gonna get one
    2x Caddy, 1x Ducato
  5. #55
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by Mischa View Post
    Fleabay USA. $129 delivered. I'm sure you could get them here at a similar cost, but I had no luck on a bit of a search.
    http://cgi.ebay.com/ebaymotors/Apexi...0167QQtcZphoto
    75mm flange too boys. The filter has this size bell outlet anyhow.
  6. #56
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by Logzy View Post
    Mate the cone idea is excellent, and the perfect part is the cone off the old ford BA GT stock airfilter, from the US mustang. It has a nice nosecone which would adapt a treat. Wish I'd kept my old one! I'm sure there would be old dirty ones available for clever people to find at ford dealers. The BA GT / new mustang has the one on the right, stock.
    Modshack housing is in, and man it's awesome. See my thread to save double posts. The whole housing unit double insulated ended up a bit over $200, but the responsiveness impressed me a lot straight away. Remains very punchy in traffic, and I haven't fully sealed it as yet! As an example I had an awesome traffic light drag with a new omega commie SV6 auto, and whilst he got a car length off the start while I slipped the clutch, I caught up in second and there was absolutely nothing between us all the way to 4th. As we caught up to the traffic ahead I gave him the thumbs up, and he must have seen my diesel sticker as he went nuts and started applauding me as I drove away. And I'd been in crawling traffic for 20 mins prior, so the punch remains in the heat. The cracker was I had my K1 kayak on the roof as well !
    MAF has caused zero problems, no VAG errors, dead normal economy and running. There is no way I will be putting mine back in. Ditch it.
    Also MIK I just discovered that the rear MAF grid three suspension support holder ring just pulls out rear wards, so if you grind the centre tabs rather than go the snip like I did, you can just pull the whole bit out.
  7. #57
    Jan 2008
    Sunshine Coast
    You must have poor tyres, that's not an option for normal driving for me!
    Second sometimes....but third....not yet!
  8. #58
    Jul 2005
    Newcastle, NSW
    Conti rubber - however I think that the roads that are around my place have grime and quite a few painted on bits that are less grippy.
  9. #59
    Jan 2008
    Sunshine Coast
    Here's the filter details...happy reading!
