On that note, I think my instant consumption rates increase faster than before, but overall economy is relatively unchanged for my grid removal.
Printable View
But your ECU should still be measuring how much (more) air is going into your engine and adjusting the fuel quantity appropriately (so no more soot than before, possibly less because of more air available ? ).
Maybe your right foot is just doing more "butt-calibration" runs, thus leading to heavier fuel consumption ? ;)
Guys it's nearly empty, and it's as per usual. Ran 5.5 average on the highway today, which is spot on. It's simply that all of a sudden I'm really taking notice of the figures, whereas before I was busy looking for XR6's.:D
I'm on target to get my usual 850kms out of the tank.
There's models?
I'll get the number off the box and let you know. I'm pretty sure it's a universal fit with a 75mm flange.
so no one has an idea where to get a pod filter fitted in brisbane?
Dude it all depends. Are you after a POD to turbo setup, or just a pod on the end of the stock stuff? The problem is that the VW isn't a commodore or falcon, so it's a bit of an unknown at regualr speed shops. I'd recommend the boys at Redcliffe Dyno if you want your car looked after by performance orientated mechanics. I'm sure the Bray's at Brendale, or any other serious, reknown performance shop around Brisbane could look after you.
Anyone could bolt a pod on ( even you dude ) BUT if it's exposed and sucking hot air, you've just LOST performance for the groovy sound. You need something in a can or box, or at LEAST with a shield.
Send Jaymz a PM as he's got VW and associated contacts here.
On the third tank of oil-ene and NO PROBLEMS without the Maf Grid. As per usual economy.
Grid is now permanantly relegated to the extra parts bin.
