Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Performance change after cam belt replacement?
  1. #21
    Dec 2010
    Dalton, New South Wales, Australia
    Because of any belt stretch, unless the position of the camshaft with respect to the sprocket is checked to be correct (the "torsion" value in that writeup) then it may not necessarily be in the right place.... the thing to ask is if they adjusted the cam sprocket or not.
    They didn't adjust the cam sprocket. "We never touch those bolts", he said. "We've never had any problems, no one else has ever complained [etc]."
    Altering the cam time by a couple of degrees moves the torque curve a few hundred RPM at most.. There's got to be something else wrong.
    As I understand it, the cam has lobes that pressurise the injectors - it seems to me that altereed cam timing may change the amount of fuel that is available to be injected when the injector is electronically opened. In turn perhaps this has altered the shape of the torque curve.
    To summarise: power has been moved up by 1000 rpm - at full power, the car used to wheelspin in first gear at 2000 rpm; now it does so at 3000 rpm. (A big diffeernce in revs when your redline is just 4500 rpm!) Highway fuel economy is 0.5 - 1 litre/100km poorer.
  2. #22
    Dec 2010
    Problem fixed. I adjusted the cam timing within the slotted adjustment range.
  3. #23
    Jun 2006
    Orange NSW
    After re-thinking how these engines actually work, i'm not surprised that's all the problem was.
    Good to see you've got it sorted, Julian.
  4. #24
    Gosford Central Coast NSW
    Quote Originally Posted by Julian Edgar View Post
    Hazaar!
    Good result!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  5. #25
    Dec 2010
    Interesting development.
    Yesterday I retarded the cam timing until, when I went for a test drive, the car had the same performance characteristics as prior to the cam belt change. So, change timing a tiny bit, go for a drive. Change it a bit more, etc.
    Too much retard resulted in the car not starting, so I then advanced it a fraction from that point until it started sweetly. Car felt to have performance the same as prior to cam belt change.
    However: today, from cold, car would not start.
    Retarded timing a fraction until it started sweetly from dead cold.
    (With the slotted holes and easy access, it's really fast to do this - 1 minute job for each cam timing change.)
    Went for a drive tonight to test some new driving lights and fuel economy was outstanding - better than ever achieved in these cold conditions. Performance is good - pretty close to how it was before cam belt change... strong power comes in maybe just a fraction higher than before (eg at 2200 rpm rather than around 2000 rpm).
    I'll check fuel economy over the next few weeks but the outcome is very interesting.
  6. #26
    Jun 2007
    Eastern Suburbs Melbourne
    Interesting indeed!
    Glad you've got it sorted, and learnt something new too. (and shared it )
    i like volkswagens
